Bubble tail lights
Have had them on lots of different cars.
Bubbles tail lights are perhaps the most widely used aftermarket conversion ever on a c3,
The look is different to stock but in no way ugly or "bubba"
Another thing is I feel in 69 gm dropped the ball going from two tail lights per side on a 68 to one per side with the silly backup light next to it for 69 and all c3's, now that looks "hack job" to me.
Two tail,brake turn lamps per side looks better and is safer.
So one cheap easy fix is the bubble tail lights and a quick simple rewire to have two tail lamps per side again,
Or if you like stock lights better get two tail lights lens per side.
Or the harder more pricey fix is like me I am running 67 caprice tail lights 3 lamps per side
It must be a hard path to follow, keeping it 100% factory original things like no radial tires on some c3's crappy radios, etc etc but worse would be a cat who wants some mods perhaps a different color paint but cant have them because they are not factory correct, lifes way too short to settle.
http://www.ecklerscorvette.com/corve...1974-1982.html
They also make LED versions
