Need Help ID-ing This Distributor/Cap/Rotor
Just a few weeks into my new addition...
It's got a 350 in it, that was re-done a few years ago. Don't know exactly how long ago though. I'm thinking MAYBE somewhere between 2-5 years ago.
30 Over, blueprinted & balanced, no date on the shop's paperwork 1 page.
SOMETIMES a bit of blue smoke comes from the Driver's Side exhaust.
Pulled the plugs, and the Driver's Side plugs appeared to be a bit damp, so I cleaned & regapped 'em. Still a tad bit of smoke, but NOT always.
YES, that's duct-tape there on the cap. It was put there by who-knows-who, but it was holding a wire in place!
I pulled the Cap & rotor to see what they look like, and they dont' look bad at all, but I DO want to get a spare or two of each. So I could use some help in ID-ing these parts.
Also, any ideas on why the blue smoke, when the motor was redone not too long ago???
Unless of course, the motor shop botched the job...
I called the motor place that did the work, and they said they purchased the shop in December of 2014, and they don't have any records prior to then.
Previous owner doesn't know either.
Thanks Again,
Ben N
BUT more likely, the heads were angle milled, so that angle between the intake gasket surface and the plane of the head gasket has changed, if the shop wanted to bump compression, this is a common practice.....the only thing you can do is basically remove the intake and check the bottom of the intake gaskets for obvious oil damage, and check the bottom of especially the head intake passages for oil evidence on it.....
the angle milling tends to open the bottoms up to the lifter valley, the only cure I know of is thicker intake gaskets, and then use a thin coat of RTV black on each side around the bottom of the gaskets.....
and add maybe 5-10 lbs of torque to the bolts.....
RTV the living hell out of the front/rear China walls also.....
obviously all surfaces need be squeeky clean.....
Pulled the plugs, and the Driver's Side plugs appeared to be a bit damp, so I cleaned & regapped 'em. Still a tad bit of smoke, but NOT always. Like mrvette said....it could be sucking oil into the head intake ports........or it could be valve stem seals not installed correctly/or loose intake manifold bolts/or piston rings not seated yet if the car was not driven after the rebuild
YES, that's duct-tape there on the cap. It was put there by who-knows-who, but it was holding a wire in place! You can buy the correct wiring connector from PepBoys and splice it into the wiring harness
I pulled the Cap & rotor to see what they look like, and they dont' look bad at all, but I DO want to get a spare or two of each. So I could use some help in ID-ing these parts. Like mrvette said....standard parts from a parts-store. Is it a Tach-drive distributor?
Unless of course, the motor shop botched the job... Same as first answers
Previous owner doesn't know either. Do a compression test if you are able/write down the readings for each cylinder/it still depends if the engine was completely broken-in
Thanks Again,
Ben N
It's a '69 'Vert.
Took it for another ride a little while ago before I took the dash apart, to see what's wrong with the radio.
Also, the car seems to be idling a bit hi at start-up IMHO @ ~1300-1500rpms (then it'll kick-down after it heats up a bit), and when it running it's "missing".
I also found a yellow/gold "Crossfire" Distributor Caps Chevy HEI diagram with the car's paperwork.
Soooo... I started to trace the sparkplug wires, to make sure they're in the correct positions on the cap, and there's a few wires that aren't in the "correct???" places according the diagram.
Right off the bat, I see that 7 & 5 are reversed (according the the diagram)
Ideas???
Thanks Muchly!!!
Ben N
It's a '69 'Vert.
Ideas???
Thanks Muchly!!!
Ben N
Here's the diagram I found with the car's paperwork.
Am I interpreting this incorrectly, or does the Firing Order look different than 18436572???
On the car right now, 5 & 7 are switched.
And I don't think 3 is where it is supposed to be... According to this diagram anyway.
