Windshield washer cover
Old Sep 8, 2015 | 10:43 AM
carretera's Avatar
carretera
Default Windshield washer cover
1969 coupe, car has a new wiper motor but does not have the washer pump/cover, I'm only interested in buying a cover, where can I find one, thanks, Tony.
Old Sep 8, 2015 | 03:31 PM
Alan 71's Avatar
Alan 71
Hi Tony,
The larger vendors carry the reproduction black plastic cover.
For instance Paragon Reproductions #12364.
Regards,
Alan
Old Sep 8, 2015 | 05:24 PM
carretera's Avatar
carretera
Default Thanks Alan
It's a slow process but I'm learning about the car more everyday, what I'm actually looking for is not the original cap that covers the washer but one you would use if the washer pump is removed, mine does not have a pump and all I'm interested in is covering the opening where pump normally goes. Is such a cover actually built? Thanks, Tony.
Old Sep 8, 2015 | 06:07 PM
JC68's Avatar
JC68
Is this what your looking for?
http://www.ebay.com/itm/1975-1979-Corvette-Wiper-Motor-Cover/381341948195?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D32481%26meid%3D4c3bebf830174e699cfca3ea249693f2%26pid%3D100010%26rk%3D1%26rkt%3D5%26sd%3D381341948195
Old Sep 8, 2015 | 08:42 PM
carretera's Avatar
carretera
Default Looks like it!
Yes that looks like what I need, ordered it will post how it works, thanks, Tony.
Old Sep 10, 2015 | 01:49 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Alan's part number is correct for a 1968-1974 but without the pump there wouldn't be anything to mount it to. The pump cover mounted to the cover with a stud that pierced the cover. (visible in the picture below).
The flat style show above for the 1975 and new motor won't work either. The motor was different and so was the motor opening the cover hides.
Willcox.
Old Sep 11, 2015 | 05:09 PM
carretera's Avatar
carretera
Default New Cover
Installed the 75-82 flat cover, it has three attachment points, 5, 7, 11 oclock, 7 and 11 oclock attach with screws like the ones used on the wiper grill, for the 5 oclock point I used the bolt that attaches the ground metal strap, hole lined up perfect. Driver side of cover has an opening for electrical connection (I suppose), I covered with a foam strip, you can barely see it in picture.
Thanks to all that replied, Tony.
Thought about Wilcox comment about cover not fitting, I bought car with new wiper motor mounted, it might not be the correct one for a 1969, it's still not functioning, have to work on that next.
To Windshield washer cover
