normal temperature on temp gauge
Old Sep 11, 2015 | 03:03 PM
ronarndt's Avatar
ronarndt
Default normal temperature on temp gauge
1968 convert with NOM 454 engine. Have only run the engine a short time due to working on other issues. Was surprised the coolant temp leveled off at approx. 190-195 on the aftermarket (cheap) temp gauge. Temp sending unit is stock, wiring from sending unit to the gauge is about the only wire on the car that Bubba has not messed with. Oversize aluminum radiator with both the stock fan and an electric fan for the big block motor. Coolant level is full. Have not pulled the thermostat to check what temp it is (hoping it is a 195). What are some of the normal operating temps you see on your car? RA
Old Sep 11, 2015 | 03:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Normal is 190-210.
Old Sep 11, 2015 | 03:21 PM
ronarndt's Avatar
ronarndt
Default temp
Normal is 190-210.
Thanks. Makes me feel less anxious. I've had three GM cars back in the 1970's with 454's, but they all were equipped with idiot lights. My RX-7 is especially prone to self-destruction if it overheats, so I am a little gun shy about seeing the needle at the top of the gauge. You ought to see the oversized radiator I have on THAT car! RA
Old Sep 11, 2015 | 03:56 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
My stock 68 427/390 with a Dewitt's aluminum radiator runs between 180 and 200 in the summer. Stock clutch fan. Prolonged highway or idling it will be in the 200 range. Around town cruising it's in the 180 range.
Old Sep 11, 2015 | 04:30 PM
Zoix's Avatar
Zoix
Default Temp
Did you mean NOM 427? We all know the 454 wasn't available until 1970. As far as temp that's usually directly related to the tstat's rating as long as everything else is up to snuff.
Old Sep 11, 2015 | 08:03 PM
LS4 PILOT's Avatar
LS4 PILOT
Stock LS4 454, not rebuilt ..original radiator ......just installed new tstat.....180 degree AC Delco part.
Ambient temp 87 F. ....running 180 -190 max....even in stop in go traffic.
Old Sep 11, 2015 | 08:14 PM
ronarndt's Avatar
ronarndt
previous owner swapped out he 427 for a 454
Old Sep 11, 2015 | 10:20 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
GM aluminum radiator
185* thermostat
gauge says approx. 175*
infrared gun says 185*
Traffic 195*
Highway 185*
To normal temperature on temp gauge
