Vapor LOC
Old Sep 15, 2015 | 08:39 PM
Dreamcar79's Avatar
Dreamcar79
8th Gear
Default Vapor LOC
My 79 L82 Vapor Locks. I have heard all kinds of Ideas. Would like to here from actual Corvette owners on this issue. Any REAL ideas? Thank you
Old Sep 15, 2015 | 08:47 PM
joewill's Avatar
joewill
this will solve your problem...
http://www.ebay.com/itm/Rochester-Ph...-/262033428451
Old Sep 15, 2015 | 09:33 PM
lowbuck72's Avatar
lowbuck72
Make sure it's really vapor lock that's causing your problem. Vapor lock is the boiling of fuel in the fuel lines, preventing the fuel pump from doing it's job since it's trying to pump vapor. If you let your car sit for 20 minutes and it starts right up, you may have vapor lock. If it doesn't start, your problem is elsewhere. It's interesting to note that fuels used to be refined with boiling points lower in the winter and higher in the summer to reduce the chance of vapor lock. With the advent of fuel injection and higher fuel pressures, modern cars no longer have this issue.
Old Sep 15, 2015 | 10:54 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I could actually hear the fuel boiling in my Edelbrock after driving in summer traffic once the engine was stopped.....then, no starting for 15-20 minutes.
The heat insulating spacer stopped the boiling.
I checked the fuel line on the frame by the passenger exhaust manifold before it entered the fuel pump with my infrared gun.........200*F after I turned the engine off!
Old Sep 16, 2015 | 09:46 AM
pltmgr's Avatar
pltmgr
As already stated you need to determine if the problem is in the carb or fuel lines. Weak fuel pump could cause problems in the lines. When problem occurs is there suction when you remove gas cap? It is my belief that todays gas is formulated for fuel injection and does not do well in carbs. Electric fuel pump or return lines to gas tank may be needed.
Old Sep 16, 2015 | 08:42 PM
Snoopysvet's Avatar
Snoopysvet
On my 1978 the heat riser was stuck in a closed position. It vapor locked all the time.
To Vapor LOC
