Do you have measuring calipers to check the a-arm hole size and the bushing outside diameter size.....should be only a couple thousands difference. Example: hole size=2.000"............ bushing size=1.998".
Put a dab of grease on the outside of the bushing to keep it from seizing when it is pressed into the hole.
Hmmm... No measuring caliper... I see an investment in one in my future.
Don't forget to put the shaft in before pressing the bushings in. They require about a .003" press fit so they will go in hard.
True true... I have thought about a ball joint press, but that only will work on one side of the arm, once one bushing is in, the shaft has to go on/in.
I would take the advice offered previously and put the bushes in the freezer for a few hours before you attempt to press them into place . It should make things a bit easier .
Remember to make a steel packing piece to put between the two sections of the arm your bushings go through. It is very easy to close up the gap between the two when pushing in your bushes with a press
That looks a little bit too big to me.
I seem to remember the lower control arm bushings being larger OD than the uppers.
I dug up an old bushing and measured it.
Yes, 225 degrees in the oven for the A arm, and the freezer for the bushing. Cut a piece of angle iron to fit tight in between the A arm holes and press/pound them in. I just did mine too I'll see if I can find one of the old ones for another measurement.
Something is not right in my opinion. You should be able to introduce that bushing up untill it meets the shoulder and then it becomes a press fit. You need a bar set between the two ends to keep from distorting it while you press the bushings in. The bushing does look as though it has a bunch of paint on it. Good luck~
Originally Posted by sstocker31
Supposed to be tight. Clean the inside bore of the A-Arm down to bare metal and you'll have better luck pressing it in.
