wire routing question
Old Sep 29, 2015 | 02:12 PM
ballen06's Avatar
ballen06
Default wire routing question
1969 corvette L46
I am installing the harness to my headlamps. I'm not sure how to rout the wires leading to the headlamps..
Do they snake through over the headlamp actuator? Or do the rout to the side of the actuator assembly?
Does anyone have a photo?
Thanks.
Old Sep 29, 2015 | 02:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The AIM shows the routing. The forward lamp harness passes through the radiator support, grounds on the top left of the support, then routes across from left to right.
Old Sep 29, 2015 | 02:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The harness is attached to the header bar and the wires drop down as shown below.l
Aims (on cd) are free this week with any order over 100.00.
Old Sep 29, 2015 | 02:51 PM
ballen06's Avatar
ballen06
Thank you very much...very helpful
My specific question is .. Does the portion of the harness that connects to the headlights run through the headlamp actuator housing (ie over the actuator itself) or is it routed to the side of the housing?
Old Sep 29, 2015 | 02:52 PM
Alan 71's Avatar
Alan 71
Hi b,
Here are a few pics from my 71.
Perhaps they'll help along with what Willcox posted.
Regards,
Alan
Here's the harness running along the headlight support. It's clipped to it in several places as the AIM shows.
You can see part of the harness turning down for the right side headlights and part continuing on for the parking and side marker connections.
Here you can see the typical connection for each headlight and the headlight warning switch.
Old Sep 29, 2015 | 04:04 PM
ballen06's Avatar
ballen06
Originally Posted by Alan 71
Hi b,
Regards,
Alan
Thank you Alan... very nice... Can you tell me if the harness portion which is attached to the headlights runs through the actuator housing or outside and around.. It's a little difficult for me to tell.
Old Sep 29, 2015 | 07:49 PM
Alan 71's Avatar
Alan 71
Hi,
I'm sorry but I'm not quite sure what you're asking.
The wires for the left side lights leave the harness before the harness passes over the canister and on the right side after it passes over the canister.
You can see the arrow pointing the right side harness.
Regards,
Alan
Old Sep 29, 2015 | 09:11 PM
ballen06's Avatar
ballen06
Hi,
Regards,
Alan
Alan .. I really appreciate all of the help that you have given me in the past.
I'm probably not making myself clear with my question.
Here's what I am after... I want to know the precise path the wiring takes after it leaves the harness and goes to the headlights.. Does it go internally through the actuator housing or does go around the housing? Probably doesn't make sense to go through the housing.
Thanks again
Bibb
Old Sep 29, 2015 | 09:28 PM
oldgto's Avatar
oldgto
I believe it goes around.... I don`t think there`s a hole for the wiring to go internally, AND it would be in the way of the actuator rods & springs, wouldn`t it?
This picture would seem to indicat it going around the canister...
Old Sep 29, 2015 | 10:14 PM
Alan 71's Avatar
Alan 71
Hi b,
It travels down right next to the outer side of the canister on both the left and right lights…. through the housing not to the side of it.
I believe you can tell that from the way the end of the harness enters the picture from the top.
Whew!
Regards,
Alan
Old Sep 30, 2015 | 05:24 AM
ballen06's Avatar
ballen06
Hi b,
Whew!
Regards,
Alan
Wow! .. Yes! the photo shows it. Thanks for your patience.
Best Regards..
Bibb
To wire routing question
