Road trip help
Old Oct 1, 2015 | 03:28 PM
COOLTED's Avatar
COOLTED
Default Road trip help
It's almost time to put her away. It's too cold at night to drive with the top off. It's not gonna be long and it will be too cold to drive in the day with the top off. I can't stand it, Summer is going away.
To cure my sadness I am trying to think of places to go next year, t-tops off. I need some ideas. So far I have Kansas City. I have the Henry Doorly Zoo in Omaha. Maybe go to Grand Island, just so I can turn around and come back. I am in southeast Nebraska and am open to all suggestions
ALL suggestions are greatly appreciated.
BTW, if you havn't been to the Henry Doorly Zoo in Omaha, you should go. Expect to spend an entire day there, maybe 2.
Old Oct 1, 2015 | 03:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The National Corvette Museum in Bowling Green is worth the trip. If you book in advance, you can also tour the assembley plant which is across the road from the museum.
Old Oct 1, 2015 | 03:50 PM
kanvasman's Avatar
kanvasman
Mt Rushmore. the WOW factor is unreal. And then you find out no tax dollars were spent on it. Double WOW> While you're there go to the Crazy Horse monument that is under construction. If you're luck you get to see the blast some of the rock.
Old Oct 2, 2015 | 12:03 PM
COOLTED's Avatar
COOLTED
Rushmore...wow it's been quite a while since I've been there, probably around 35 years. Beautiful drive. Good suggestion!
The Corvette Museum is on my list as well. That's one of the places I'd like to go. Google says only a 12 hour drive. Seems like it should be longer than that.
To Road trip help
