Hello
Old Oct 9, 2015 | 09:27 AM
Lowrider47421's Avatar
Lowrider47421
4th Gear
Default Hello
Hi new here just bought my first c3 1981 love it already needs a lot of tlc but I'm willing to make her a diamond again has a 355 motor runs excellent already stripped out the interior going to redo my question is the driver side bonding area is pulling away from the car the previous owner put a screw in it to hold it together �� should I remove the whole front clip to repair it or ? Advice would be appreciated
Old Oct 9, 2015 | 09:32 AM
Dean_Fuller's Avatar
Dean_Fuller
Welcome...can you post a pic of the problem area? There are MANY bonding areas on your car. Hard to tell which you are talking about.
Dean
Old Oct 9, 2015 | 09:33 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Welcome to the Forum and the best with your new ride.
Old Oct 9, 2015 | 09:40 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Congrats on the new car!
From what I have read in the "Paint/Body" forum.....removing the complete front end is un-necessary....
the loose area only needs to be cleaned well and new bonding adhesive squirted onto the loose area.....
then pull the panel back into place the correct amount with something like a tie-down strap......
then let it cure for a day or two without moving the car.
The expert members can advise you better.
Old Oct 9, 2015 | 10:19 AM
65GGvert's Avatar
65GGvert
A 351 Ford engine? Congratulations on your car, I hope you enjoy the hobby as much as I do.
Old Oct 9, 2015 | 11:04 AM
Street Rat's Avatar
Street Rat
Welcome!
You will find this forum very informative. Congrats on the purchase of the '81. I own one myself. We would love to see some pictures of it.
Old Oct 9, 2015 | 04:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Lowrider47421
...should I remove the whole front clip...
My advice is never to remove a factory installed clip unless it's 1000% necessary, and then to think it over six or seven times before deciding to do it.
...or?...
Rebond the area with the clip in place.
Old Oct 9, 2015 | 05:14 PM
Dean_Fuller
The only reason I can think of to remove the front clip is to repair the birdcage...short of that , I would leave it on. I had to remove mine to fix rust on my birdcage.
Old Oct 11, 2015 | 11:00 AM
Lowrider47421
4th Gear
Lol no not ford bored with mild cam
Old Oct 11, 2015 | 11:19 AM
Lowrider47421
4th Gear
I posted pictures in my album before restoration of the body areas that need attention thanks for the advice what is the best bonding material to bond the clip back to the car
Old Oct 11, 2015 | 10:10 PM
Lowrider47421
4th Gear
Sorry I meant a 355
To Hello
