Interior experts please ....
Old Oct 11, 2015 | 04:41 PM
The Phantom's Avatar
The Phantom
Default Interior experts please ....
So, what's the trick to dash pad removal?
Dave
Old Oct 11, 2015 | 05:02 PM
Crafty12's Avatar
Crafty12
Dave
Which dash piece? Driver side lower I would at least drop the column if not completely removing it. Top pad I took out each window pillar trim and even then I had to flex the top pad slightly to get it out.
Go slow and don't force it.
Old Oct 11, 2015 | 05:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
It's been a while, Dave, but it's pretty straight forward. Remove the two pillar covers and then remove the screws holding the dash to the lower panels. There's also one holding it in each door. Don't force it as it's probably the original and can be easily cracked. (Ask me how I know.) I may have missed something so others may chime in.
You might want to pick up a GM shop manual for your car along with the assembly manual. They're well worth the investment. Good luck.
Old Oct 11, 2015 | 05:36 PM
oldgto's Avatar
oldgto
Originally Posted by Jud Chapin
Remove the two pillar covers and then remove the screws holding the dash to the lower panels. There's also one holding it in each door.......
I think there`s an additional brace that bolts to the fire wall and the bottom of the pad.... just right of center?
Old Oct 11, 2015 | 05:41 PM
Richard454's Avatar
Richard454
As Jud said-
PLUS-
To remove the side windshield header panels- you have to remove (can just loosen the sides as it's they are tucked underneath it) the sunvisors AND top windshield header panel.
Two screws on each side of both left ad right panels- three across the top - then two bolts to drop the steering column.
You WILL have to flex the dash edges to remove it- carefully. Even if the windshield is out!!! Oh- there are 6 clips attaching the back of the dash to the base of the windshield that just might be rusted tight.
My windshield is out and it's still a tight fit.
Good luck!!
Richard
Old Oct 11, 2015 | 05:44 PM
Jud Chapin's Avatar
Jud Chapin
Yes, now I remember that damn thing.
Old Oct 11, 2015 | 05:52 PM
The Phantom
Thanks folks, it was the little flex that was the trick. Just can't believe how dry all these components are, they are extremely brittle I can see replacements in the future.
Thanks again.
Dave
Old Oct 11, 2015 | 08:16 PM
Tom73's Avatar
Tom73
As things age they dry out and get brittle. I know that as I age I am getting dryer and more brittle.
Old Oct 12, 2015 | 05:59 AM
oldgto's Avatar
oldgto
To say the least!!
Old Oct 12, 2015 | 11:48 PM
74Ken's Avatar
74Ken
Dave, you got the body on already
Old Oct 13, 2015 | 05:25 PM
The Phantom
No such luck, I have decided to see what other wonders the car has in store for me! Now that the dash / AC / wiring and an old mouse nest had been removed it seems there are some minor bird cage issues to resolve at the bottom corners of the windows.
The body now lives on a recently acquired body dolly and I can move it around easily.
Dave
Old Oct 13, 2015 | 05:41 PM
Jud Chapin's Avatar
Jud Chapin
Dave
You're making progress, Dave, and that's what's important.
To Interior experts please ....
