a frame bushing problem
Old Nov 16, 2015 | 08:09 AM
croaker's Avatar
croaker
I've never run across one with a split. The rental AZ had was solid. Guess I should get out more. I would like this if it was on FB
Old Dec 3, 2015 | 05:00 PM
Darlas81's Avatar
Darlas81
I got this tool from Amazon for around 92.00 with free shipping. The problem I had with the lower control arm was that the smallest "C" fitting was just a wee too tight to fit into the inside of the bushing and miss the arm. The upper bushings came out as you say "easy
peezy." The lower, I drilled out the rubber, made my own penetrating solution of 50/50 ATF and acetone, shot some of that in there, and one side came with the air chisel. Tonight, it's more cussing the last one out. I've crushed it already, staying away from the arm, and got it really loose, but not out. Tonight..............keeping my fingers crossed.
