Old Chapman lock experts chime in
Old Nov 1, 2015 | 09:08 PM
myoriginal77's Avatar
myoriginal77
Default Old Chapman lock experts chime in
Hello everybody,
Well - the new project arrived - '77, needs everything -
But first, it has an old Chapman under the dash alarm / key lock which looks like there are a few wires hanging here and there.
The problem is it will run but then it dies, if you move the bundle of wires it will run, then dies, move the bundle, runs a little longer, dies. Sometimes it runs longer, sometimes not.
I have heard the Chapman system grounded the ignition so I'm thinking this may be part of the problem.
Thanks,
Frank
Old Nov 2, 2015 | 03:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by myoriginal77
Hello everybody,
Thanks,
Frank
We had one in a car in our shop and we stripped it out... I looked forever trying to find info on it and in the shop time is money. It was cheaper to pull it out and install another system vs. trying to fix the old one. Installation of a new system is way too easy.
I couldn't find any schematics on it anywhere...
Willcox
Old Nov 2, 2015 | 10:04 PM
myoriginal77
Thanks Willcox,
I plan on removing it but my fear is that wires have become detached and I'm not sure where they go.
I too searched and searched with no luck.
Thanks again -
Frank
Old Nov 3, 2015 | 01:16 PM
0Willcox Corvette
Former Vendor
Thanks Willcox,
Thanks again -
Frank
Frank- I have the factory schematic on my repair and installation site. I'd go to that and use it to verify the wires... then yank it out.
Willcox
This is it, it's a tracer schamatic. Just right click and copy it... then paste it into your paint program on your computer and save. You can then trace the wires with the line option in that program.
Old Nov 3, 2015 | 08:40 PM
myoriginal77
Thanks Again Willcox !
Big help for Saturdays list.
Frank
Old Nov 4, 2015 | 08:37 AM
70BBvert's Avatar
70BBvert
Hello everybody,
Thanks,
Frank
Chapman locks worked by grounding out the ignition, it was a pretty simple system. Should be easy to remove, IIRC it was only two wires but it has been 30+ years since I installed one...
We used to do the same thing with a hidden toggle switch
Jim
To Old Chapman lock experts chime in
