Power window switch
Old Nov 2, 2015 | 05:56 PM
Hale584's Avatar
Hale584
Default Power window switch
1969...which way does the power window switch go...long ploe to the rear or to the front? I'm wanting to pull back on the switch to raise the window.
Thanks,
Glen
Old Nov 2, 2015 | 07:43 PM
Sayfoo's Avatar
Sayfoo
Thanks,
Glen
Mine are just the opposite--forward to raise the window. Not sure if this is original or not.
Old Nov 3, 2015 | 07:20 AM
74Ken's Avatar
74Ken
mine was like that when I got it, I turned them around when I had the console out.
Made more sense to pull up the switch to make the windows go up.
Old Nov 3, 2015 | 08:09 AM
C376FL's Avatar
C376FL
Mine operate the same as yours, I am not sure if that is original or if the owner turned them around some time in the past.
Old Nov 3, 2015 | 09:26 AM
Hale584's Avatar
Hale584
Which way is the switch positioned? Does the long pole go to the rear or to the front? I want to pull them up and push them down. Thanks for the replies!!
Old Nov 3, 2015 | 10:07 AM
74Ken's Avatar
74Ken
it's been about 2 years since I did than. all I can remember is it was opposite to what the cable connected wanted to do.
Can you hook them up temporary and see which way?
Old Nov 3, 2015 | 10:51 AM
Hale584's Avatar
Hale584
I can....I was just trying to do it one time and move on.
Old Nov 3, 2015 | 05:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
http://repairs.willcoxcorvette.com/1...-installation/
This orientation of the power window switch is the factory way. However, some customers like to switch the motion from pulling back makes the window go down to pulling back makes the window go up.
For 1968-1976 cars you’ll need to either trim away a portion of the alignment tag or smash down the tag made into the retainer. Then invert the switches. For 1977-1982 cars one must remove either the plastic nub on the shifter console plate or the must remove a portion of the tang off the switch housing.
-Willcox
Old Nov 4, 2015 | 11:45 AM
loup68's Avatar
loup68
Army
I can't believe GM had pulling back as down? I installed a used setup in my car and made
pulling back as going up. I didn't know any better! I still can't believe they engineered it the other way. Lou.
Old Nov 4, 2015 | 12:25 PM
7T1vette's Avatar
7T1vette
Just hook it up and try it out before you finish mounting it. That's the easiest way to be sure. Keep in mind, you can orient the SWITCH in a specific way....but if the power leads going to the motor have been switched (from normal assembly practice), the switch will operate in reversed fashion.
Plug it in, power it up, try it out~~ That's the only way to be certain of how it is going to function.
Old Nov 4, 2015 | 01:18 PM
Hale584's Avatar
Hale584
-Willcox
Thank you!
To Power window switch
