Horn/Relay Question
Old Nov 8, 2015 | 10:39 AM
Iceaxe's Avatar
Iceaxe
OK, that means everything in my 70 works like it's supposed to (including the clock) except the key buzzer. The horns work great, interior lights work great. So I'm guessing someone has unplugged the warning buzzer at some point. Where would I look? The previous owners were not Bubba and would have disconnected the buzzed in a reasonable way if they didn't like the buzzer.
Not that I actually want a key warning buzzer as I find them annoying, but I like to know I can make it work.
Old Nov 8, 2015 | 11:22 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The horn relay is the buzzer on the 1970........ If your not buzzing with a key in the ignition cylinder then the issue is probably the buzzer switch in the column.
Willcox
Old Nov 8, 2015 | 11:29 AM
D_Williams's Avatar
D_Williams
Willcox,
If the buzzer switch was bad, would that also prevent the interior lights from turning on with the key in and door open?
Old Nov 8, 2015 | 12:08 PM
D_Williams's Avatar
D_Williams
I just tested my buzzer by grounding the small pink wire (furthest on the right in this photo) and it works. So it looks like my buzzer switch may be at fault here.
Old Nov 8, 2015 | 08:16 PM
0Willcox Corvette
Former Vendor
Originally Posted by D_Williams
Willcox,
Nope.. different circuit.
