The left most 3 wires to a plastic plug holds a fuse for the air conditioner. See it in the picture from my 73:
Not sure about the other ones. Clean them off so we can see the color. The one with the small plastic connector, if green like mine, goes to the temperature sensor on the engine block as part of the TCS system.
Fran
I see one wire that looks like white cloth was just like mine on my 76. I thought bubba had put in the harness, glad to see it must be original. I have not seen where it went to down towards the starter.
I'm sure the guys here on the forum can help you out on all the wires.
Good luck
Larry
Hi O,
HF is right I believe.
All but one look like wiper motor/washerpump wiring to me.
The 2 small wires with the barrel connectors are for the washer pump, the single wire connector is a ground, and the large connector is for the wiper motor.
These pictures are from a 71 but I believe your car is similar.
The 2 wires to the odd 'hook' connector is a coil connection.
Good Luck!
Regards,
Alan
Blue /yellow with barrel connectors into washer pump:
2016 C3 of Year Finalist
Originally Posted by Alan 71
Hi O,
Good Luck!
Regards,
Alan
Barrel connectors into washer pump:
Yellow and black:
Man is that a beautiful engine bay. Got any wide shots of it
Hi O,
Yes, the dust flap is notched low down on each side so it can be tucked and and the notched areas keep the that part of the flap in place.
I occasionally see cars that have the flap just laying on the a-arm which is o.k., but not the way they were intended to be installed.
Regards,
Alan
