Windshield Wiper transmision posts
I need what I have been told is windshield wiper transmission posts. The post that you attach you windshield wipers too. mine are worn and allow the windshield wiper to go past side of windshield. I have been told that you cannot buy them new from any of the parts suppliers. Any suggestions where I can find these?
Here's just a suggestion….
Before I bought a new transmission I'd check a couple of things:
First, check if your wiper arm has an adjustment screw 'A'… it controls the 'sweep' of the wiper blade. Earlier cars had it, but I'm not sure if 78s still did.
Second, check the wiper arm adjustment at the wiper motor ….. it controls how far the arms travel.
Third, check the condition of the 'key' on the transmission shaft… it 'fixes' the wiper arm on the shaft and allows the other adjustments to actually have effect.
Lastly, check the 'key-way' in the wiper arm that the 'key' fits into… it also allows the adjustments to have effect.
Perhaps your problem is caused one of these things.
Regards,
Alan
#1 Screw 'A', showing how it adjusts the sweep.
#2 Adjustment at wiper motor
#3 Square 'key' on wiper shaft.
Square 'key-way' slot in arm
To the OP, take off the nut on the output shaft of the motor mechanism. This will free up the linkages and you can further troubleshoot as per Alan's instructions. The posts should not have play in them.
Good Luck!
Regards,
Alan
