Are there any tuning tricks to get the most out of '75 L-82 4 speed with A/C.
I want to keep it stock, removing the converter and smog pump is not an option.
If you want to keep it stock than there is nothing you can do
Timing is a good way to bump performance on these.....
Install a curve kit that will get you about 12 degrees initial and 36-37 total. Put a timing tape on the balancer or install a balancer with 0-60 markings.
The real problem is the exhaust.....research your options there....like a Magnaflow hi-flow cat.....and mandrel bent exhaust/headers....
Big gains there.....and it supports later mods.
The Performer EPS is a good upgrade for the stock intake.....
A mild camshaft is imperceptible to the eye.
Bowl blending of the cylinder heads is also a viable option.....
It will never pull wheel stands but the above mods can eek another 60 horsepower or so out of it....while looking almost stock.
I hear you about stock and smog concerns, but you might consider better heads that look stock but improve everything. Those original 882 heads are pretty lame, plus I did an accurate cc compression calculation on an L-82 at one time and found it to be really 7.9:1.
These things are well known....but what happens a lot of times is the owner will go overboard on the cam....
Keep everything mild....and it will retain that all important torque....
That cam is not bad at all....Crane makes a very similar one....
You can make a fun cruiser with the right mild combo....all in what you want, and how much $$$ you want to spend.
L-82 is an excellent base.
He said he wants to keep it stock. If that's the case, then as mentioned above: timing, mild mods to the distributor (can't been seen) and carb adjustments are pretty much it. Start pulling apart a motor with age and miles on it to replace a cam, and now you're looking at a cam / lifter kit, timing chain, pulling the distributor, intake, water pump. radiator, ps pump, alternator etc. It's not like you can just slide a new cam in.
Where do you stop with that job, and now you have a bunch of clean / new / painted parts on the front of a motor with miles on it. It will look anything but stock and original when you're done.
Nice post......
Unless his state won't allow the cat to be removed ......not much you can do . The exhaust is the prime culprit limiting options, slamming the door shut on performance. Headers and true duals , cheap upgrade.
Old school part like a set 350 /350 heads would be cool keeping with the original apparence theme , adding the compression. But unless you fix the exhaust, to me it's just not worth it.
