Silver Sport magnum t-56 6 speed for a 1968 corvette
Old 11-28-2015, 10:53 PM
regatta
regatta's Avatar
Default Silver Sport magnum t-56 6 speed for a 1968 corvette
Has anyone with a 68 installed a tremec 6-speed transmission and the pros and cons of doing it. Apparently Silver Sport Transmissions have a perfect kit that has the transmission, crossmember, driveshaft and the complete kit to make this conversion. The price is costly, but the 6 speed overdrive might be worth it
I Would just like to know if any of the older C3's have done this and how it
worked for them.
Old 11-29-2015, 06:11 AM
a striper
a striper's Avatar
I converted my '69 and my '72 about ten years ago. I used the modified Viper box. It has a mechanical speedometer output which is nice to have. This version bolts up to a typical old four speed bell housing. I converted the cars to have removable crossmembers and added a fiberglass "bump" to the floors near the passenger seat to clear the yoke (Mark Williams 1350 quick release) and new driveshafts from a local shop. A lot of little stuff but not rocket science. I'm in the process of replacing the 383 with an LS3 in the '69.
Old 11-30-2015, 06:00 PM
Corey_68
Corey_68's Avatar
Have a LS2/T56 in mine. Pretty pretty straight forward, If you have the $$$ and skill DO IT.
Old 11-30-2015, 08:38 PM
cagotzmann
cagotzmann's Avatar
worked for them.
Its nice to see a complete kit, but its not required to do the swap.
I converted my 78 TH350 to a T56 magnum
Here are my notes. Even with a complete kit there will be problems to solve. You may still have drive line angle problems with any of the kits because the T56 Magnum is a longer transmission.
https://www.corvetteforum.com/forums...-corvette.html
To Silver Sport magnum t-56 6 speed for a 1968 corvette
Quick Reply: Silver Sport magnum t-56 6 speed for a 1968 corvette
