brake issue
Old Dec 7, 2015 | 02:10 PM
ballen06's Avatar
ballen06
Default brake issue
1969 corvette L46
I installed my calipers on my front wheels. When I try to install my pads ..they don't fit .. can't get them in. It's like the rotor is too thick...
Is the rear rotor thinner than the front rotor and I have them reversed??
Large brake cylinders are on the front .. right?
I'm doing something wrong.
Please help..
Old Dec 7, 2015 | 02:19 PM
blue by you's Avatar
blue by you
did you put a C clamp on and push the piston into the calipers
Old Dec 7, 2015 | 02:24 PM
ballen06's Avatar
ballen06
Thanks ... I finally did that and they slipped in .... whew!!
Old Dec 7, 2015 | 03:33 PM
ronarndt's Avatar
ronarndt
Default brakes
Ecklers sells a set of "clips" that go over the pistons and hold them compressed to make sliding the new pads in place. Well worth the $10, especially if you are working on other stuff and leave the caliper hanging for a while. RA
Old Dec 7, 2015 | 04:52 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Brakes
Make sure your pistons are back in the bores. You may have to uncap the master cylinder to allow it to overflow. Find a piece of wood that is a little thicker than the rotor. Put your pads in the caliper. Do not put the top pins on. Put the wood between the pads. Slip the caliper assembly over the rotor. The wood will pop out the top. Bold down the caliper, insert the pin and secure with the carter pin. I use a block of wood thicker than the rotor and about three quarters the size of the pads. Make sure your bleeders are ALWAYS on top. The larger calipers go on the front. Bleed the system and top off the M/C. You should be good to go. Good luck. Jerry
Old Dec 7, 2015 | 09:29 PM
ballen06's Avatar
ballen06
Thanks Jerry ... I like your wood idea...
To brake issue
