wipers not shuting off properly
Old Dec 8, 2015 | 07:20 PM
tljr's Avatar
tljr
Default wipers not shuting off properly
I have a 1976. My wipers work fine till I go to shut them off they retract but they wont shut off they pulse up and down and will only shut off if I hold them down with pressure after a few seconds they will stop pulsating and shut off. has anyone run into this before if so how did you fix it
Ive already put a brand new wiper motor in and a new switch and new wiper arms
Tony
Old Dec 8, 2015 | 09:30 PM
530planeman's Avatar
530planeman
Tony
Tony
Do you have an override switch under steering Column ? Also Willcox has some info on their site on how to test Not sure on this ear although I would not hold them to stop might burn up your new wiper motor
Wes
Old Dec 8, 2015 | 10:26 PM
D_Williams's Avatar
D_Williams
That sounds like a wiring issue, but I think the wiring is slightly different than my 70, so I'll just wing it
Do you have both high and low speeds?
If not, then it's probably the black wire at the wiper motor (black/white at the switch) that is broken somewhere or not making a good connection
To wipers not shuting off properly
