Best outer window seal?
Old Dec 15, 2015 | 04:55 PM
mdeslyper's Avatar
mdeslyper
Default Best outer window seal?
1976 coupe. Need to replace my outer window seals. The part that attaches to the exterior door (window removal required to install). I have heard that some vendors quality is better than others. If any one has had good/bad experiences with this part please share.
Thanks,
Mike
Old Dec 16, 2015 | 04:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Thanks,
Mike
Yes.. there are some junk felts out there.... the best way to tell is the junk wipes are rubber, the good wipes are cat hair covered. We pulled the rubber wipe felts from our site.
Coupe
https://willcoxcorvette.com/catalogs...oduction+69-82
Conv
https://willcoxcorvette.com/corvette...oduction-69-75
Old Dec 16, 2015 | 07:22 PM
mdeslyper's Avatar
mdeslyper
Thanks - any trick to installation? I figured aligning the glass back in door would be the difficult part. Is this correct?
Old Dec 16, 2015 | 09:38 PM
0Willcox Corvette
Former Vendor
There is one trick, even on the good felts. Sometimes the special clips don't want to seem to hold so we will drill a extra screw hold where (if needed). We usually try to open the clip up a bit before we do that. But if you do drill a new hole make sure to put a stop block on the drill bit, you don't want to drill a hole in the fiberglass.
Willcox
Old Dec 17, 2015 | 11:09 AM
mdeslyper's Avatar
mdeslyper
Thanks for the tip.
Old Dec 17, 2015 | 11:43 PM
mark79,80's Avatar
mark79,80
Thanks,
Mike
It is not nesessary to remove the window to replace the outer seal. Lower the stops, or remove them from the bottom of the window tracks.
The window can then be lowered below the outer seal.
Old Dec 18, 2015 | 05:30 PM
0Willcox Corvette
Former Vendor
Remove the lower stops and the door window pad adjuster... it's tight but it can be done.
Willcox
To Best outer window seal?
