OK, What's the Trick????
Old Dec 16, 2015 | 12:29 PM
madam's Avatar
madam
Default OK, What's the Trick????
I'm installing a new E-brake console in my 76. What's the trick to getting the slider onto the brake lever. The handle is to big to pass thru the rectangular hole in the slider and I don't see how the handle is removed from the lever.
Also, is the one screw that secures the rear center of the console accessable from under the car.
Any help is appreciated.
Old Dec 16, 2015 | 01:06 PM
MelWff's Avatar
MelWff
1. The screw is accessible from the rear compartment. Remove the jack compartment storage container and reach in.
2. Doesn't the slider have a cut in the side to permit it to slip around the handle?
Old Dec 16, 2015 | 01:50 PM
Haggisbash's Avatar
Haggisbash
You could try softening the slider in very hot water, I didn't have to put a split in it to get mine to fit.
Old Dec 16, 2015 | 02:26 PM
Alan 71's Avatar
Alan 71
Hi m,
Here's the bolt MW described…. this is looking from the jack compartment side.
Regards,
Alan
Old Dec 16, 2015 | 03:06 PM
Blue Ridge 67's Avatar
Blue Ridge 67
All sliders come with a split on one side so the easily fit around the brake handle. I have sold 100's of them
Old Dec 16, 2015 | 03:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Look at the slider carefully and you'll see that it has a split. Without this split you can't install it and you wouldn't believe how many customers get them and call because they think the slider is defective.
Willcox
Old Dec 17, 2015 | 11:12 AM
madam's Avatar
madam
Originally Posted by Alan 71
Hi m,
Regards,
Alan
Thats the tricky trick, thanks Alan.
Old Dec 17, 2015 | 11:22 AM
madam's Avatar
madam
As far as the slider, upon closer inspection I see a partial parting line on the underside of mine. I'll have to complete the cut into the handle area. I purchased this one from Mid America.
Thanks for the guidence fellas. Gotta luv this forum!!
Old Dec 18, 2015 | 04:24 PM
madam's Avatar
madam
Default Now, What's The Trick part ''B'' ????
Put everything back together but . . . . . . the front of the slider runs into the back of the shifter console when the E-brake lever is disengaged. It's like the slider has no where to go.
What am I missing??
Thanks.
Old Dec 18, 2015 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi m,
Make sure the slide is being fed UNDER the shifter console properly.
Regards,
Alan
Old Dec 18, 2015 | 06:32 PM
jnb5101's Avatar
jnb5101
Alan
Are you absolutely sure you didn't work for GM in the 70's?
Old Dec 18, 2015 | 06:41 PM
Alan 71's Avatar
Alan 71
Hi jnb,
If you take a car apart far enough, often enough, you end up with pictures like those….
plus paying attention to what people are asking about.
Regards,
Alan
Old Dec 18, 2015 | 10:45 PM
Wee's Avatar
Wee
This is one of the things on my to-do list.
Brian
To OK, What's the Trick????
