Head Light Dash Indicator Question
Old Dec 18, 2015 | 01:33 PM
CrossWired's Avatar
CrossWired
Default Head Light Dash Indicator Question
When I turn my head lights on regardless of High or Low beam the dashboard Head Light Indicator stays on as well. Is it supposed to stay on if the headlights are on regardless of High or Low setting?
Old Dec 18, 2015 | 01:48 PM
MelWff's Avatar
MelWff
are you talking about the high beam indicator, if so only when using high beams. If you mean the headlight door light it should go off when the head light doors are fully open.
Old Dec 18, 2015 | 01:54 PM
CrossWired's Avatar
CrossWired
Yes Sir the on the center dash console the label is "Head Lamps" and when I hit the dimmer switch on and off on the lower left floor the indicater stays on. But when I turn the Head Lights off the indicator light goes out.
Old Dec 18, 2015 | 02:05 PM
MelWff's Avatar
MelWff
there are small switches on the headlight door mechanism. Assuming the headlights do fully open it sounds like the switch/s need adjusting.
https://willcoxcorvette.com/corvette...g-switch-68-82
Old Dec 18, 2015 | 04:33 PM
Alan 71's Avatar
Alan 71
Hi CW,
Here's the switch MW describes on each of the headlight door's mechanism that shuts the headlight warning light in the center gauge bezel off when the doors are fully open.
It should turn the warning light off automatically.
Regards,
Alan
It's the black plastic 'button' switch in the center of the picture.
Old Dec 18, 2015 | 06:19 PM
CrossWired's Avatar
CrossWired
Originally Posted by Alan 71
Hi CW,
Regards,
Alan
Thank you both!! That light is driving my wife nuts and she just wants to put tape over it. LOL
Old Dec 18, 2015 | 06:28 PM
Mooser's Avatar
Mooser
Those switches are phenomenally easy to break
Be very carefully working on and around them
M
Old Dec 18, 2015 | 06:41 PM
65GGvert's Avatar
65GGvert
My 72 had one of the switches broken where it bolts to the housing and it showed the same symptoms as yours. I replaced the switch (not expensive) and all is well.
Old Dec 18, 2015 | 06:53 PM
Alan 71's Avatar
Alan 71
Hi,
The switches can come apart to repair.
Notice the entire threaded snout is only connected to 1/2 of the body of the switch…. THAT'S why they break off so easily!
Didn't they realize what they were setting us up for? Have become probably the easiest things to break on these cars along with wiper pump ports.
Regards,
Alan
Old Dec 19, 2015 | 07:49 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I know this isn't my post but,Alan, you are the answer man and your supply of pictures is awesome. Thanks for being a good guy. I've gotten so many answers from you and everytime I click on a new post, there you are. Thanks!!
I'mm not trying to single Alan out because I've gotten answers from everyone here and I want to thank everyone else too. Merry Christmas to everyone here, guess I'll start my own thread
To Head Light Dash Indicator Question
