Hi b,
I really think the duct goes 'under' that's why it's shaped the way it is….the drop 'down' of the connection of the center duct and then the 'rise' back up once it gets past the column.
I would think the center duct goes in first…I believe the drawing does show some sense of 'sequence'.
It looks to me that the LH duct is a 'slip fit' in the connection at the center duct and then is held in place at the LH outlet with a screw and u-nut (#3&4).
Regards,
Alan
Under the column.. and you want to hook up the vent side first, then couple them together... it's easier to install it that way. Alan is correct, for the center dash to be installed the center duct must also be there so the center is first.
-Willcox
Hi b,
Regards,
Alan
The driver side is the side that was removed and torn way more often than the passenger side... There wasn't much behind the passenger side dash to require that duct to be removed. Higher in/out rate, higher failure rate, less used available.
After the dash pad and column are in place and under the steering column. 71 AIM C60, Sheet A7.
ITEM #5
Alan,
I am expecting my AIM any day now, but can you tell me if the AIM book lists GM part numbers for each part? Specifically #5 the L.H. duct in the above drawing?
IMHO,
Willcox
I didnt see a 1968 LH air duct available in anyones catalog, is this something not available? Or only found as a used item?
Steve
I don't think it's being reproduced due to the number of 68 Corvettes that came equipped with AC, only 5,664 out of 28,566. I looked around for a long time and finally found one. It was VERY expensive and was far from perfect, but I was happy being able to locate one.
