C3 1981 Stringray brakes
Old Dec 24, 2015 | 07:17 AM
TotalContracting's Avatar
TotalContracting
3rd Gear
Default C3 1981 Stringray brakes
I have a possible leak in my brake system, but before it is identified I would like to know what type of brake fluid I should be using to top up the brake fluid
Old Dec 24, 2015 | 08:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Likely to be DOT 3. Your owner's manual will probably mention it.
Old Dec 24, 2015 | 08:31 AM
fishslayer143's Avatar
fishslayer143
Dot 3 was recommended in 1981.. however you can use Dot 4 , it is compatible and has a higher boiling point.. NEVER use Dot 5 ,it is not compatible without completely flushing the system and replacing the rubber hoses
Old Dec 24, 2015 | 09:59 PM
TotalContracting
3rd Gear
Cheers, thanks very much for your help, have a great Christmas
Old Dec 24, 2015 | 10:00 PM
TotalContracting
3rd Gear
Thanks heaps, hope you have a great Christmas
Old Dec 26, 2015 | 12:05 AM
Giddy-up Go's Avatar
Giddy-up Go
Probably DOT 3 but you may want to do a complete change to help keep moisture out and switch to DOT 5 . Check it out and do some reading. I am going with DOT 5 in my rebuild!
Old Jan 5, 2016 | 12:37 PM
pippo350's Avatar
pippo350
You can usa a good DOT 4 like motul RBF 660 with hight boiling point.
Old Jan 5, 2016 | 11:24 PM
454Luvr's Avatar
454Luvr
You'll need to replace the entire hydraulic system if you do that. When DOT5 and DOT3 contact each other, they coagulate and form a jelly-like substance. For what it would cost to thoroughly clean all the "wet" components before introducing DOT5 into the system, you could probably replace everything. Incidentally, you probably know this, but DOT5 is more compressible and not as well suited to harsh use. I've only ever used it in lightweight hotrods (like T-buckets) where all the components are painted. A spill or leak of DOT3/4 on those can cost thousands to repair.
To C3 1981 Stringray brakes
