Console plates
Old Dec 27, 2015 | 08:51 PM
Rodney Slavin's Avatar
Rodney Slavin
Default Console plates
So here is my dilemma. My wide body car is a 1970 but has a 77 dash and adapted 77 wiring harness along with the javelina Corp digital gauges which I believe is why it had an adapted wiring harness for the dash and engine harness. What I am trying to do is figure out if I can put the 70 console plate and e brake housing with the 77 console instrument cluster or does only the 77 console plate mate up to the console instrument cluster. Thanks in advance.
Old Dec 31, 2015 | 12:49 AM
Rodney Slavin
does anyone have a 1970 center dash and a 1977 center dash to see if I can mate the 77 to the lower console and plate
Old Dec 31, 2015 | 04:57 AM
Rotonda's Avatar
Rotonda
Rodney,
Without pictures of your dash, no one is going to be able to help you. There are too many to give you any sort of answer.
Old Dec 31, 2015 | 07:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not sure you can do what you want to do, but the 77 left and right dash pads were essentially the same as the 69-76 pads. The big change for 77 was not the pads but the new style center cluster and plastic shifter console. The lower front corners of the 77 cluster bezel are designed to fill the gap the new bezel left at the ends of the older style dash pads. The plastic bezel has no lower mounting studs used by the 68-76 style bezels.
You might want to consider using a 68-76 metal center cluster bezel.
Old Dec 31, 2015 | 09:29 AM
Rodney Slavin
Originally Posted by Rotonda
Rodney,
Unfortunately my dash is apart and out of the car while I work on this horrible hack job of wiring. I may just have to get a lower console and hope they will mate up. I can send pictures of my console and cluster if that would help.
Old Jan 1, 2016 | 07:26 AM
Easy Mike's Avatar
Easy Mike
...I can send pictures of my console and cluster if that would help...
Pics might help, but based on your first post, you have a plastic 77 center cluster you are wanting to match up to earlier style (68-76) shifter and ebrake consoles.
Old Jan 5, 2016 | 09:41 AM
Rodney Slavin
Yes exactly what I'm hoping to accomplish. I don't know if it changes much but it is 79 center cluster instead of a 77.
Thabks
To Console plates
