vin number help
Vin on pad is T043CPH, C11S117363. If the C 11 is for third month of production is this possible for a June 07 build date on trim pad? Vin pad # match vin on car. It's a convertible with a repaint on it. Not original color but nice looking and asking price is 25,000.
Ted
your 17363 vin sequence number means your car was built in was built about mid-April 71..
so you have an engine stamp with a invalid date on the broadcast code. a car that was built mid april 71 and a trim tag with a june 07 date of production on it. not something I would pay original engine money for.
25K for a big block convertible is a pretty good price even for a non original motor. you have to decide what your requirements are and if this matters to you. I would pay easily 25k for a big block convertible if the condition was right.
WELCOME!
Looking at a 71 CONVERTIBLE!! NICE!!!
I agree with Joe's info. The Trim Tag car assembly date, engine assembly date, and sequence stamp on the engine pad, must all coincide.
Start by taking another look at the assembly stamp on the engine pad to see if there are 4 numbers not just 3 as you posted.
The CPH indicates a 454 engine with 365 hp built to be used in a car with a 4-speed transmission.
We need to have all the info and have it be accurate to tell for sure just what the car is you're looking at.
Regards,
Alan
http://www.corvettecenterusa.com/Cor...ne%20Codes.pdf
https://www.corvetteforum.com/forums...-a-series.html
WELCOME!
Regards,
Alan
Well, that helps because we now have a May built car which works for the engine assembly stamp of April 30 and the vin sequence of 17363 which works as the car it went in.
NOW!…… there are many other parts that have date codes and part numbers that make them appropriate for a particular car. I don't know if you;'re aware of that if that even matters to you.
One thing you SHOULD check are the stamps on the transmission case which will indicate when it was assembled and what car (sequence number) it was installed in.
Regards,
Alan
Regards,\
Alan
Regards,
Alan
As much as I know you'd like opinions about it I really can't even offer a guess about the value of the car you're looking at (I'd be doing you a disservice if I did) without having a LOT more information about it, and a series of pictures showing the exterior, interior, engine compartment, and frame/running gear.
For someone who's interested in 'originality' the fact that the car is painted in a color other than the one indicated on the trim tag lowers it's value by the cost to repaint the car in it's original color, BUT, to someone not interested in "originality" the color change may matter not matter a single bit.
What are you looking for in a Corvette? Does the color change matter to you?
Regards,
Alan
