No heater
Old Jan 10, 2016 | 11:31 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default No heater
I replaced the heater core on my 1978 put the interior all back together but I still don't get any hot or even warm air thru any of the vents. When moving the switch between defrost, heater, etc it blows out of the right vents. When I move the hot cold switch I can see the cable moving the bracket on top of the housing. I had heads and intake work done and I am getting a feeling they did not put in a thermostat ( engine never getting over 160) but even then I would think that I would at least get warm air.
Old Jan 10, 2016 | 11:59 AM
'75's Avatar
'75
Do both the heater hoses get warm?
Old Jan 10, 2016 | 12:12 PM
RockyL32's Avatar
RockyL32
Good question! I never thought to check. I'll do that.
Old Jan 10, 2016 | 12:47 PM
Paul L's Avatar
Paul L
Have you connected the small vacuum line on the heater shut-off switch in the heater hose? (Can't remember if it is the 5/8" or 3/4".)
Old Jan 10, 2016 | 12:57 PM
RockyL32's Avatar
RockyL32
Originally Posted by paul 74
Have you connected the small vacuum line on the heaters shut-off switch in the heater hose? (Can't remember if it is the 5/8" or 3/4".)
I did not know about a vacume line to a cut off valve. Is it under the hood or in the cabin?
Old Jan 10, 2016 | 01:05 PM
RockyL32's Avatar
RockyL32
Ok under the hood I see the valve on the heater hose and a vacuume line connected to it. Where does the other end of that vacuume line go it seems to dissapear near the firewall?
Old Jan 10, 2016 | 01:15 PM
'75's Avatar
'75
That valve receives vacuum when the control is set to max ac and causes the coolant flow to be blocked. Normally the vacuum controlled valve is open to coolant flow with no vacuum signal.
Old Jan 10, 2016 | 01:29 PM
RockyL32's Avatar
RockyL32
So if I disconnect that vacuume hose and put my thumb to it I should not feel any vacuume unless in max ac, if I do feel vacuume I have something hooked up wrong.
Old Jan 10, 2016 | 01:31 PM
'75's Avatar
'75
Correct, you may have vacuum there with all the controls off also, I can't remember.
Old Jan 10, 2016 | 01:33 PM
RockyL32's Avatar
RockyL32
Ok I'll check that. Thank you
Old Jan 10, 2016 | 03:54 PM
The Hot Rod Grille's Avatar
The Hot Rod Grille
2015 C3 of Year Finalist
Did you "burp" the air out of the new heater core? I have seen situations where there was an "air lock" in the replaced heater core that did not allow the coolant to circulate through the heater system. No circulation = no hot air out the vents.
Old Jan 10, 2016 | 07:22 PM
Paul L's Avatar
Paul L
That is a possibility but he did not answer the earlier question. Are the heater hoses hot? Before and after the valve.
Old Jan 10, 2016 | 09:05 PM
RockyL32's Avatar
RockyL32
Plans to work on the car whent out the window today. I will check the vacuume to the valve and see if the heater hoses warm up tomorrow. I have changed out a few heater cores ( not corvette) and I don't think I ever burped one of them. I'm guessing to do that you just disconnect the hose on the output side and run it till coolant bubbles out.
Old Jan 11, 2016 | 11:50 AM
RockyL32's Avatar
RockyL32
I'm getting a little vacuume to the valve! I disconnected the vacuume line from the valve, let the car warm up and I am now getting warm air in the car. Thank you all for your help. Would it be ok just to leave that vacuume line disconnected for the winter and revisit the problem come summer or would that damage the valve?
Old Jan 11, 2016 | 05:11 PM
'75's Avatar
'75
Won't hurt anything, plug the line with a golf tee. In the summer you will want it working to keep excess heat out of the cabin.
Old Jan 11, 2016 | 07:21 PM
Paul L's Avatar
Paul L
I agree but would just replace the valve.
Old Jan 11, 2016 | 07:53 PM
CPTCroaker's Avatar
CPTCroaker
Hate to ask because it seems too simple, but do your heater hoses have shut off valves installed?
Old Jan 12, 2016 | 02:31 AM
Skip Burney's Avatar
Skip Burney
Whats a heater
To No heater
