Repair old clock
Repair old clock
I would like to have my clock rebuilt. has anyone used "The clock works"? or is there someone you can recommend. I connected it to 12v and it wound and ran for 7 seconds, if i gently tap it then it will run for another few seconds. I don't think it is a lost cause, just needs cleaned and oiled.
Don't waste your time. Been there....done that. The original Borg clock is a nifty device; but "reliability" is NOT it's strong suit. Fix it and it will fail again within 5 years (usually much less).
Buy a clone clock with a quartz movement...or replace the gearset in your clock with a quartz movement. In the long run, you will be glad you did.
Or, you could just convert that gauge location to something else: vacuum gauge, A/F meter, oil temp, whatever. Hey, you already have 'quartz' on your wrist and a cell phone with accurate time!
My clock is now oil temp. I fitted a new original style internal mechanism to the clock and bench tested it for a week and it was fine, installed it in the car and it lasted about a week, contacts stuck and burnt out the coil.
Received 2,878 Likes
Hi 71f,
I used Corvette Specialties of Md West.
It's still working fine after 10 years.
Not cheap.
Regards,
Alan
(760) 568-6450
Not cheap.
Regards,
Alan
(760) 568-6450
I'll repeat a notation from the owner's manual Maintenance Schedule that says to have the clocks serviced annually, for lubrication and cleaning. Following this, will increase the lifespan of the original clocks.
is there a way to take it apart to clean and oil it? I have seen clock oil on the internet.
Hi 71,
I've not taken one apart but since they can be repaired they certainly come apart.
I think the problem that plagues the clocks is their electrical system employs a set of points to 'wind' the clock every so often. As time goes by these points can 'weld' together.
Regards,
Alan
Regards,
Alan
Hi 71,
Regards,
Alan
Regards,
Alan
Thanks,
The quartz units are very nice.
71frameoff (01-13-2016)
http://www.pcfred.com/Vettetip/FixC3Clock.htm
A lot of people have done this to their clocks. You can buy them from Wilcox Corvette
I'd put a little micro switch in series with the clock. This way in storage, you could turn off the clock and it wouldn't run down the battery. Hide the little switch so it's not seen.
It would be better with a little capacitor (similar to the 'pop' filters for the Delco radio).
The points inside the Borg clock can get 'dirty' and unable to draw current necessary to fire the 'rewind' solenoid. BUT, the contact arm can also fail from structural fatigue. Cleaning won't cure that.
How does one service that clock "annually"? By removing the gauge cluster every year to put a drop of oil on it? I DON'T THINK SO!!
The only thing the quartz clock will do is keep the correct time and NOT FAIL. The second hand will 'bump' every second, instead of every 1/2 second. That's the only visible difference in the quartz movement replacement.
Quartz is a 'no brainer' on this one. Mine has been re-failed (if Obama can make up words, so can I ) for several years...but I'm not opening up the gauge cluster until something important needs to be done. Then, I'll convert to quartz.
71frameoff (01-14-2016)
Beuler? Beuler?
I guess we'll never know...
