Bleeding brakes
Getting my 80 back on the road and one of my last jobs is to replace the brake fluid.
I have an access to a pressure bleeder which means I can apply pressure to the MC and force the fluid through.
I am right to think that I have to depress the brake pedal during the bleed!?
Also, how many bleeding nipples should there be on the rear callipers (2 or 3)
And, should I use TPF tape on the nipples?
Thank you
Rear calipers have TWO bleeders at the uppermost side of the caliper. There is a plug on the lower side opposite the steel line.
Sometimes a rebuilder might put a bleeder there but ignore it.
As for Teflon tape on the bleeder threads it shouldn't be necessary as the seal is actually at the base of the bleeder to the surface it presses against.
But I myself do use a thin bit of Teflon tape to keep bleeders from freezing up, altho some may frown on this.
I've come across the occasional NEW bleeder that's hard to seal and then went back to the original.
Paul, did you get my PM last week?
Yes, I have the email, been away haven had a chance to reply, but will shortly.
Thank you so much for your help
IF the system DID NOT go dry...then bleed it til you get clean fluid. If the fluid in the reservoir is dirty...I get it out and fill it with clean fluid BEFORE I connect my attachment to the master cylinder so it saves on brake fluid. And fluid that does not look CLEAN/CLEAR like new fluid ...I consider 'dirty' and I get it out of the reservoir.
DUB
And I agree...but since I bought my pressure bleeder about 25+ years ago....bleeding brakes and hydraulic clutches is/are a joke. Literally a 'one man' job.
DUB
I gravity bled the right rear first, then the left.....
In the front....I had a buddy help me do the pump,pump,pump,crack....
Four cracks on each side in the front.....
This car had a rock hard pedal.....
I read these threads and wonder what the big deal is....
My 66' was the exact same way......super easy.
The only tip I can give is crack the bleeder in the back that is highest....and bench bleed your master...(this is not as big of a deal as some make it out to be either...)
Pressure bleeding is sure nice to have.....but I do not own one after 25 years of messing around.
Just my rant....carry on
Jebby
If it has anything to do with how the bias in the brakes is changed when installed.....I would be hard pressed to use it.
DUB
Jebby
YES...a pressure bleeder is great to have....and it only took a few years working for myself to realize that I NEEDED to buy one. The amount of time I have saved in 30 years of doing occasional brake jobs has well paid for itself time and time again.
DUB
One thing I keep telling myself I want to buy is a A/C evac/charge deal....but I just do not do enough of them.....
I DO need a 3/8" Snap-On cordless electric impact though....
Jebby
DUB
DUB
Dont get an a/c machine if you can avoid it. Every time you hook up your $5k or more machine to a system to evacuate it, you cross your fingers and pray to the gods of a/c that bubba didn't dump some stop leak in there to plug up your machine and possibly ruin it.
Rob
Rob
Anyhoo.....what Pressure Bleeding systems are you guys using? I may buy one.....
Jebby
It has two halves...fluid on the top and it is separated by a membrane and the air is below it...so you are pressurizing the container and forcing the fluid though the system. VERY USEFUL for me when I am working on the later year models with anti-lock brakes and have to push the fluid through at a higher pressure...roughly around 22 psi.
http://www.zoro.com/gearwrench-brake...g&gclsrc=aw.ds
DUB
Rob
GREAT HEADS-UP!!!
Always something more to have to worry about.....JUST GOTTA LOVE IT!
DUB
Jebby
You need to bleed the brakes in the following fashion...
Left rear inner
Left rear outer
Right rear inner
Right rear outer
Left front
Right front
