Replacing Engine
Old Jan 22, 2016 | 12:30 AM
Mark Pitts's Avatar
Mark Pitts
1st Gear
Default Replacing Engine
The original engine was a two-piece rear main seal. Try to replace with a one-piece rear main seal engine. The oil pan is hitting the steering cylinder. Which is keeping the engine from setting into place. Any suggestions on how I can solve this problem. This is a 1979 L82.
Old Jan 22, 2016 | 08:32 AM
jnb5101's Avatar
jnb5101
Corvette oil pans are different than other GM pans. Someone else that's familiar with the difference between the two engines (one piece and two piece seals) will have to chime in on whether or not the pans are interchangeable.
Old Jan 22, 2016 | 10:27 AM
Street Rat's Avatar
Street Rat
I had to buy a Canton pan from Summit. Perfect.
Old Jan 22, 2016 | 12:00 PM
CanadaGrant's Avatar
CanadaGrant
I installed a crate ZZ4 with one piece main in my wife's 78 L82 a number of years ago and it slid right in. I had the idler arm unbolted from the frame at the time to get steering clearance for the install but once in I have an inch and a half or more clearance with everything bolted up as the drop in the pan is behind the steering.
Old Jan 23, 2016 | 09:26 PM
carriljc's Avatar
carriljc
Default I got an oil pan from a later model chevy passenger car...
when I installed a Ram Jet 350 in my 68 I looked around a while and finally went to a boneyard and just got a later (mid 1990s I believe) gm passenger vehicle (I forget what, but it was a larger low vehicle). anyway, the 1-piece rear main seal oil pan that I got fit fine below the steering assembly.
Just take your old oil pan with you and you can find one with a similar shape to fit.
Old Jan 24, 2016 | 05:18 PM
loup68's Avatar
loup68
Army
As stated above, the ZZ4 oil pan fits our Corvettes. Lou.
To Replacing Engine
