1971 c3 gear selection
3 is D.
If it truly is 1 2 3, he has a reverse valve body, commonly modified for drag racing. If that's the case, you usually have to shift them manually through each gear and cannot go straight to "3" for drive like it would be if standard 3 2 1.
Both operate om the same manner PRN321. You can put the shifter into any forward range and the car will start out in first gear, then upshift to the range specified on the shift indicator. You can downshift at any time, but there are 'inhibitors' which prevent the car from going into a lower range IF doing so would cause the trans to overspeed.
I don't know if ALL turbo-hydramatic transmissions would automatically shift out of a lower gear on their own[when left in that range] or not. I only know that the one in my (then new) 1968 Chevelle 396 SS would shift on its own out of low gear. I could keep the hammer down and, with a strudy-enough jock-strap, it would eventually shift to 2nd. And shift it did!! Hard and fast...fishtailing a bit till it settled down. That was fun.
My later 'fast' cars had stick shifts in them; then I did the 'family' thing and got out of the rapid car market. When I got back into C3's and had another THM, I didn't really feel the need to "test" that feature out. Maybe they all do it. I don't know.
NORMALLY, one would put the shifter into 1st range and shift to 2nd at the proper rpm. Or, if the governor was set up well, just put it in Drive and hold the pedal down; the governor will shift it automatically when the set rpm is reached (usually a lot lower than one would desire, as set from the factory).
