Fixing Up The Rear End
Nam Labrat
Received 4,179 Likes
Lots of work to get the new look!
You put some time sweat and elbow grease to make that change from ugly to purdy! Looks fantastic - keep up the good work!
LOL, No. It's been rode hard & put away wet
It was sitting in a guys garage for 8 years. It was originally from Texas. It was so loaded with dirt & rocks, etc. I believe I have removed at least 5 lbs of dirt so far. It would hardly run and kept puking gas out the bowl vents. When I tore the engine down the cylinder walls & rings were in bad shape, but good enough the .030 corrected that issue. Has some blow-by. I was hoping that I could get away with some new gaskets & a rattle can tune and save for a big block, but that will be a little later than originally planned.
It's saving grace is the interior is in good shape. The only thing I have had to replace so far is the visors & steering wheel. But that was because I didn't like the small cracks it had around the edges of it. One thing I cannot stand is a nasty interior.
Now on to the front end. I have the Borgeson power steering and all new suspension & steering parts to install. The motor is ready to be picked up from the machine shop. I'm hoping to have it back on the road soon.
