Outside door handle '73 (question)
And when you removed the handle...the rod that was attached to the outside handle STILL HAD the special clip on the end of the rod. THAT CLIP is critical and HOW it is installed is critical also. Many people do not install it correctly or leave it off and the rod ac actually begin to wok into the hole where the rod goes and cases for problems due to movement OF THE ROD in relation the the handle itself.
YES...but be CAREFUL...because you can lengthen this rod TOO MUCH...and when you do that...that extra length is now pushing on the arm of the latch mechanism..and what happens ( or can happen) is that when you go to LOCK the door...you will be able to LOCK it...BUT you will not be able to UNLOCK it or it will have a bad bind in it when you try to do so.
ONE TIP:
The flat metal lever ON the latch mechanism....that the door handle rod clips onto. When I am setting up the outside door handle.....I reach in and can lightly press down on this flat lever and when I feel it STOP ....THAT is the point I start from and adjust the door handle to....THEN I check it. NOW...I DO NOT have the special clip caged onto this flat lever so I can keep changing the length of this rod until I get it where I want it...becasue I am going for a specific angel of the flapper to actually be this point that the door opens.. Once I get it right....I slide the clip on and clip in the rod and I am done. AND like I wrote above...I AM checking the LOCK-UNLOCK function also.
Here is that clip that goes on the end of the rod where it slides into the door handle. This clip gets attached to the rod FIRST and locked in place ..then the rod slides into the handle. THAT is how that works.....and NOT...REPEAT ...DO NOT install the rod INTO THE HANDLE and then this clip....THAT IS WRONG!!!
Ecklers part number:25-101283-1
DUB
ONE TIP:
http://www.parts123.com/parts123/yb....5Z5Z50000036b#
DUB
DUB - is this the special clip you are referring to? If so it was nowhere to be found. I will have to order it. Is there only one way to install it? If not, I will need some pointers since I was not able to see how it was installed. I couldn't get your link to work but I think I know what clip you are referring to and will use your tip. Thanks.
AS you can see in the photo that 'karol' posted...the CLIP goes on the rod FIRST....then you put the rod onto the handle .
DUB
