Speedo/Tach lights
Old Feb 20, 2016 | 09:24 AM
Bigdwh's Avatar
Bigdwh
Cruising
Default Speedo/Tach lights
When I turn on the headlights the signal lights on the dash come on and stay on but the speedo and tach lights do not. The headlights and turn signals work fine it's just the the dash lights that aren't on! The gauge lights are working normal and go on and off like they should. When I turn the headlights off everything is normal. Any ideas what it could be?
Thanks Dennis
Old Feb 21, 2016 | 07:59 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Sounds like a bad ground. I had a tail light not grounded correctly. Did the same thing and the brake lights n that side didnt work right. My guess.
You'll need someone to step on your brake pedal for you to check
Old Feb 21, 2016 | 08:19 AM
danh77's Avatar
danh77
On my 77 when I got it the left t/s indicator would illuminate when the headlights were turned on. All my lights functioned properly. I wound up replacing my h/l switch.
Old Feb 22, 2016 | 10:44 AM
7T1vette's Avatar
7T1vette
The tach/speedo gauges have a separate wire for grounding them. It runs from the back side of the housings to the birdcage post in front of the driver's door. Any 14 ga. wire (or larger) run from the rear of the gauge housing to ground will get the job done.
Old Feb 22, 2016 | 09:36 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dennis... .
What year is the car?
If it's a 1978-1982 you may have a PCB issue behind the dash cluster. But without the year it's hard to help you.
Willcox
Old Feb 22, 2016 | 09:57 PM
Bigdwh's Avatar
Bigdwh
Cruising
Originally Posted by Willcox Corvette
Dennis... .
Willcox
Sorry it's a 1981.
Old Feb 23, 2016 | 03:33 PM
0Willcox Corvette
Former Vendor
The lamps in the center console and the lamps in the speedo housing are on the same circuit which makes me think you might have a failure in the pcb behind the speedo and tach. It's easy enough to check out.
Once you have the housing out of the dash look at the printed circuit and see if any of the fingers are touching one another.
Willcox
1978-1982-corvette-speedometer-and-tach-housing-removal-instructions
Old Feb 23, 2016 | 07:28 PM
Bigdwh's Avatar
Bigdwh
Cruising
Willcox
Thanks, I'll take it apart this weekend to check the board.
Dennis
To Speedo/Tach lights
