1971 350 4 speed
Old Feb 28, 2016 | 03:05 PM
mpro71vette's Avatar
mpro71vette
Default 1971 350 4 speed
Hi All, On my 71 I'm not getting a temp read out, could this be the thermostat? Do I have to drain the rad to change it?
Old Feb 28, 2016 | 03:41 PM
LongRoadHome's Avatar
LongRoadHome
I think the temp sensor is either going to be located atop the intake manifold near the radiator hose thermostat housing or between cylinders 1 and 3 at front drivers side engine head.
You might want to look for problems with the wires there.
Should not need to drain anyway.
Someone else can probably answer better than me about what's wrong with it, or gauge.
Old Feb 28, 2016 | 04:02 PM
Alan 71's Avatar
Alan 71
Hi mpr,
I believe you can check that the thermostat is opening by feeling the heat in the upper and lower radiator hoses after the engine has been running for a while.
The water neck/thermostat is high enough that the radiator doesn't need to be drained to change thermostat.
Have you checked the temperature sender and it's electrical connection for the dash gauge that's located in the side of the left side head between the first 2 plug?
Regards,
Alan
Location of temperature sender for dash gauge.
Old Feb 28, 2016 | 04:05 PM
mpro71vette
Originally Posted by Alan 71
Hi mpr,
Regards,
Alan
Thanks guys, I'll check the temp wire.
Didn't find a wire on the electrical connection on the left side after the first cylinder. It was working not sure how something like that could come off.
Old Feb 28, 2016 | 04:15 PM
Alan 71's Avatar
Alan 71
Hi,
You should see the wire with a woven 'sheath' on it to protect it.
Regards,
Alan
Old Feb 28, 2016 | 04:22 PM
mpro71vette
Hi,
Regards,
Alan
YES! I found it, it was hiding. I plugged it in and got my temp! Thanks for the pics Alan.
Old Feb 28, 2016 | 04:43 PM
Alan 71's Avatar
Alan 71
Hi mpr,
Isn't nice that on occasion a 'fix' is easy!
Regards,
Alan
Old Feb 28, 2016 | 04:49 PM
LongRoadHome
Great to hear! I'm (re)learning this stuff myself. Haven't had a 350 SB Chevy since the 1970's.
Old Feb 28, 2016 | 05:13 PM
mpro71vette
Its been 7-10 years for me, I didn't realize how much I forgot!
Old Mar 2, 2016 | 08:11 PM
LT1M21Vette's Avatar
LT1M21Vette
Really, this is one of those thing where it is much easier to replace the sensor, the thermostat and flush the coolant all at once.
It is cheap, and you fix it once.
To 1971 350 4 speed
