1970 vette vin #'s
Old Mar 8, 2016 | 11:32 PM
wroughtiron65's Avatar
wroughtiron65
Cruising
Default 1970 vette vin #'s
I have a 70 vette and the number on the driver A pillar is not a correct VIN number. Any way to find the original vin #. Engine is not original either. Has a new crate 350.
Thanks for any help
Old Mar 9, 2016 | 08:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by wroughtiron65
I have a 70 vette...Any way to find the original vin #...
A VIN derivative is stamped on the transmission provided the tranny is original. The frame is also stamped in two places with a VIN derivative, but the locations are very difficult to see with the body on the frame.
There may be a vehicle certification sticker on the driver's door.
Old Mar 9, 2016 | 08:34 AM
Alan 71's Avatar
Alan 71
Hi wi,
Welcome!
If the car still has it's original frame you may be able to see one of the 2 partial VIN stamps on the top surface of the left side frame rail.
The one near where the driver sits can't be seen with the body in place but the one near the #4 body mount can be seen.
The second one can't always be read though.
Good Luck!
Regards,
Alan
Old Mar 9, 2016 | 09:41 AM
wroughtiron65
Cruising
thanks the frame is undercoated but I believe the tranny is original. Will look there
Old Mar 9, 2016 | 10:00 AM
Brcmpbl's Avatar
Brcmpbl
You haven't actually said what's on the A-pillar for a number. Have a picture?
Old Mar 9, 2016 | 10:26 AM
wroughtiron65
Cruising
no picture it is stamped MA10654
Old Mar 9, 2016 | 10:30 AM
Alan 71's Avatar
Alan 71
Hi wi,
MA for the state of Massachusetts?
Here's what you're looking for on the transmission (side of the case's flange on a 4-speed, Automatic transmissions are stamped too.
Regards,
Alan
Larger digits describe when the transmission was assembled and in what configuration, and the smaller digits are a partial VIN. The same stamp/gang holder was used to stamp the engine pad and the transmission in St.Louis.
Old Mar 9, 2016 | 03:25 PM
BBCorv70's Avatar
BBCorv70
Sounds like it was given a state VIN.
Why are you looking for the original serial number?
Old Mar 10, 2016 | 06:21 AM
Staylor63's Avatar
Staylor63
Originally Posted by Alan 71
Hi wi,
Regards,
Alan
Very cool picture of the stamping tool!!
Old Mar 10, 2016 | 07:23 AM
Alan 71's Avatar
Alan 71
Hi,
When you see the tool, the box of loose stamps, the heavy glove, and the lead? hammer…. you can begin to understand the variations and errors that occurred on the engine pads.
Regards,
Alan
Old Mar 10, 2016 | 10:35 AM
joewill's Avatar
joewill
The tranny, frame and engine will only give you a VIN derivative, not the entire number.. although one can extrapolate the entire VIN from that.
yes a blue certification sticker on the drivers door , if it exists and is original, and is readable, will have the entire VIN.
What does the title say?
To 1970 vette vin #'s
