rear leaf spring?
Old Mar 13, 2016 | 03:57 PM
377's Avatar
377
Default rear leaf spring?
i have a 73 L-82 i need a rear leaf spring need help i dont want it to sit high looking for stock ride high what spring metal or composite ? and my spring is 9 leaf i was thinking going to 7 for better handling? were to buy it thanks
Old Mar 13, 2016 | 04:11 PM
Bloodzone's Avatar
Bloodzone
I went with the 79 version of this VBP 360 spring. Very happy with ride quality and height. Weight reduction is a bonus.
Old Mar 13, 2016 | 04:15 PM
John Ulrich's Avatar
John Ulrich
Go composite for a nicer ride.
Old Mar 14, 2016 | 12:54 AM
tpfarm's Avatar
tpfarm
I just replaced my stock 9 leaf spring on my '73 with a 9 leaf steel spring from Willcox Corvette. I am pleased with the quality and the ride height is about one inch higher with the new spring.
Old Mar 14, 2016 | 09:51 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I ended up with the VBP 330#. Started with the Hyperco that I bought via Van Steel. The rear ride height was way high and 10" bolts were suggested to bring it down. Not to my liking and the Van Steel folks were most accommodating in swapping it for the VBP piece. With it the car rides and looks great.
One point if you go composite yo will need some good shocks to go with. Bilsteins are the typical choice.
Old Mar 14, 2016 | 12:38 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I went with a 360 lbs glass one and it's great ride , not stiff at all or high , no new shocks
Old Mar 14, 2016 | 03:30 PM
377's Avatar
377
thanks for the info
Old Mar 14, 2016 | 03:41 PM
mardyn's Avatar
mardyn
I'm still planning on removing the top two leaves from my spring package in order to soften the ride and lower the car slightly... unless someone has a really good reason not to??
mardyn
Old Mar 15, 2016 | 12:13 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I think if you have it apart , I'd put a glass one in and new bushings , you won't be sorry .
To rear leaf spring?
