Wheel cleaner ideas?
Old Mar 20, 2016 | 11:49 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Default Wheel cleaner ideas?
Anyone have a easy way to clean up the aluminum wheels?
I have the factory ones and they are a bit streaky and a bit dingy. Nothing major, but I'd like to clean them up.
Thanks!
Old Mar 20, 2016 | 12:54 PM
jim in oregon's Avatar
jim in oregon
Thanks!
There are a number of spray on wipe off cleaners for aluminum wheels.
Most require a bit og elbow grease using a softer scotchbrite pad..
I's easiest to do with the wheels off the car of course..and at waist height..A small pad of 0000 steel wool wetted with the wheel cleaner helps on the badder streaks..but go gently..jim
Old Mar 20, 2016 | 01:25 PM
Rcdizy's Avatar
Rcdizy
I know of a wheel refinishing shop that said they put them on a tire changing machine.., and hold a buffer to the wheel while the machine is rotating. To get an even finish.
Sounds easier than trying to do it yourself.....
Old Mar 21, 2016 | 11:05 AM
REELAV8R's Avatar
REELAV8R
I started with steel wool. single 0 then up to #000. May need some sand paper maybe 220 to 400 grit or so if you have any deep scratches, I recommend wet sanding over dry.
Then after the sand paper and the steel wool I went with Mothers mag and aluminum polish. How much you polish will determine the level of shine you get.
It is a lot easier polishing with something powered vs by hand.
http://www.autogeek.net/motmagalpol....FQmSaQodCBAIGg
http://www.walmart.com/ip/15137628?w...818072&veh=sem
Old Mar 21, 2016 | 01:30 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Never Dull and elbow grease is a good combo.
Old Mar 21, 2016 | 11:56 PM
Sunstroked's Avatar
Sunstroked
If you want a really fantastic looking job, there are polishing shops that will really make them pop. If they are corroded, it's going to be a lot of work on your part with the above mentioned post #4. For light work, I bought a power cone kit from mothers. Attaches to your drill and does a great job for quickly detailing my polished aluminum cragars. And other polished parts in my engine bay. A tip, take general purpose baking flour, dip a rag into it and wipe off the black residue on the part.
Old Mar 22, 2016 | 06:33 PM
news2me's Avatar
news2me
When I got my 77' the wheels looked like hell. I picked up a can of Mothers Mag and Aluminum Polish. Mothers also makes a Polishing wheel, its about the size of a baseball and it goes on a drill. I put the Mothers Polish on my wheels and rubbed it out with the Polish Wheel and the drill. They look 100 times better then before..
Old Mar 22, 2016 | 07:20 PM
billschroeder5842
Thanks- this weekend is the first that I've had off in a while, so I think I have my car project figured out!
To Wheel cleaner ideas?
