Interior facelift
Old Mar 26, 2016 | 04:33 PM
gavanm01's Avatar
gavanm01
Default Interior facelift
Anyone knowledgeable about interior dye--spray or wipe on over plastic and vinyl interior parts? I need to replace some panels that come unpainted and want to match the rest of the interior. I'm thinking the best way is to paint (dye) everything for best match. On other threads I'm picking up good info to dye carpet with regular RIT dye. My main concern remains the vinyl and plastic parts. Would appreciate some input on this please.
Old Mar 26, 2016 | 06:16 PM
DUB's Avatar
DUB
AS you should.
The problem with vinyl parts is that were made with the color in it. So they generally last due to nothing can wear off. When applying a dye on these type of parts and NOT wanting it to flake off is ADHESION. So getting the part CLEAN and possibly using a good adhesion promoter such as 'BULLDOG' will aid in making sure you are attempting to give the dye the best chance to stick and not flake off. in many instances...I also apply a non-glare clear on the part so it has some protections and does not have too much shine or luster....which often times depends on what my customer wants....regardless of what the factory provided.
The plastic parts are much the same way.
DUB
Old Mar 26, 2016 | 09:50 PM
Street Rat's Avatar
Street Rat
I just tried my hand at this on a small scale. I used the SEM products in spray cans. I used the cleaner first, then the adhesion promoter, and finally the dye. I was skeptical about using three products to dye a piece of plastic but it worked great. Kinda pricey though.
Old Mar 27, 2016 | 05:48 PM
DUB's Avatar
DUB
YEP...to get profession excellent results...it does cost a bit more sometimes. And these added products generally have a specific purpose and SHOULD NOT be overlooked.
Kinda like you getting a new concrete driveway and NOT wanting to pay for the aggregate in the mix to give it strength and save a few bucks....does NOT pay off in the long run.
DUB
Old Mar 27, 2016 | 06:34 PM
79C3tnd's Avatar
79C3tnd
You MUST clean them well to remove anything that would keep paint from adhering properly. Good old Dawn and water works great. Pat them dry, and let them dry thoroughly before attempting to coat them. I like to use a hair dryer or compressed air to clean out the nooks and crannies as well before a good air dry. Ensure you have no "fuzzies on the pieces from any drying cloths obviously. Use a good adhesion promotor. As for dyes, I have used SEM, but actually prefer the spray dyes from Corvette America. They cover well, and dry with a matte/satin finish like an original part. Hope this helps...
To Interior facelift
