75 /76 floor pans
https://www.corvetteforum.com/forums/paint-body-138/
96 views and no replies is why no replies were given. This is and can be a touchy issue due to it being a part of the structure of the body.
And to answer you question. Replacing the floor fans that WERE STEEL with fiberglass/SMC ones from an earlier year would NOT be something that I would do.
They offer steel floor pans that can be installed...and that is what I would do for you if your car were in my shop.
NOW...you can do as you wish...and I am NOT writing that it can not be done. But there are some things that come into 'play' that may cause this idea not to work....and those 'things'...I can not see....but bad rusty steel is one of them...and that also depends on how much of the floor pan you plan on using when you take it out of your donor car.
DUB
what I have at this point is a 75 with great floor pans but are old stile glass and the good body is a 76 and the foot well as I can see at this point is all rusted from being on or close to the ground for 15 years were seats are seams to be good and solid but haven't pulled them as of yet so if the rust go's further than what I can see at this point then I plan on replacing hole pan but if just wear the feet well are then I was thinking of the glass ones like the earlier ones are just wondering if any one has tried it
Macki
Macki
One again...you can fix this problem how ever you choose. And if 50 people come and tell you they took the steel floor pans out and installed fiberglass floor pans....all I would say to that is that those 50 people did SPENT a lot more time and effort to get that 'idea' to work then buying what they needed and replace the steel floor pans.
DUB
DUB
DUB I was just using that as a point this is not my first vette for one and all I am trying to find out is if it has been done and what others might have done . Just because I am new to this Forums dose not mean I have no experience in doing this kind of work
As I wrote...your car...do it your way. I do not judge what you do.
I have no clue on what you know...or how many Corvettes you have done. So me giving a response that offends you....I am not to blame because I do not know if you know everything or nothing at all. I am giving an opinion from my decades of experience. And when questions are asked that deal with structure....how am I supposed to respond to the question??? Because.... If the person had years of experience...they would not post a question they should already know.
Thus... you should already KNOW the answer to the question about floor pans.....CORRECT????
I respond to questions NOT ONLY for the person who is asking...but also for those people who do not know and are searching for an opinion on the same question they may have and come across this thread.
I am responding from a professional point of view. I do this type of work every day. So I am not going to write something that pleases people when I know it is incorrect. I know what you need to do to fix this...or at least if it were in my shop how I would fix this....so.....I guess we will see if anyone 'chimes' in with the answer that satisfies you.
DUB
DUB
He may come off as strong opinioned, but he gave me advice when I installed my metal pans in my 77. Dub is one of the guys on this forum that most people take heed to what he says. It wasn't that hard to install the pans, but I'm a welder.
