harness clips
Old Apr 9, 2016 | 05:23 PM
steffan's Avatar
steffan
Default harness clips
where could I get some of those clips that are in the front wiring harness. the ones that hold it to the header bar.
not the straps.
Old Apr 9, 2016 | 05:38 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Look at the right side of your screen.........near the bottom of the listing of Forum Vendors you will find the PARTS category......some of those Vendors/Parts Suppliers will have just what you need.
Old Apr 9, 2016 | 06:28 PM
Alan 71's Avatar
Alan 71
Hi s,
The arrows in the AIM point both 'metal clips' and 'plastic ties'.
The page you posted is for the headlight washer hoses. So the additional plastic 'ties' ties shown are for attaching those hoses to the existing harness.
So are you looking for 'clips' or "ties", or both?
Regards,
Alan
Old Apr 9, 2016 | 06:52 PM
steffan's Avatar
steffan
the photo was just for the location. the metal clips attached to the drivers side fender I have. the straps shown in the front I have. I see that the washer hose straps to the harness. I am looking for what holds the wiring harness up.
should be a plastic piece that is wrapped into the wiring harness then, pushes into holes on the header bar? Thanks.
Old Apr 9, 2016 | 07:02 PM
steffan's Avatar
steffan
thanks
Old Apr 9, 2016 | 07:39 PM
steffan's Avatar
steffan
I never noticed before but my harness is on the bottom. I would like to it make it proper. needs a rewrap.I have one of these in the wrap. searching vendors sites didn't turn up anything. I am thinking this is what holds it in place
Old Apr 10, 2016 | 10:20 AM
steffan's Avatar
steffan
ok found something that will work, didn't find anything at vendors sites.Thanks.
Old Apr 10, 2016 | 11:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by steffan
thanks
Black plastic push in buttons. They are part of the harness assembly.
Old Apr 10, 2016 | 11:40 AM
Alan 71's Avatar
Alan 71
Hi s,
I had to replace one of them on my harness.
I may have bought what you found.
I trimmed the round button into a rectangle like the original.
I was able to slip it into position on the harness without disturbing the black plastic wrap.
Glad you found what you needed.
Regards,
Alan
Old Apr 10, 2016 | 12:27 PM
steffan's Avatar
steffan
hence the existing clip statement in the AIM. this should work
Thanks.
Old May 2, 2016 | 12:14 PM
steffan's Avatar
steffan
any advice on trying to figure out where these clips go in the harness? have been looking at some photo's here and there.Thanx.
Old May 2, 2016 | 01:44 PM
Easy Mike's Avatar
Easy Mike
...any advice on trying to figure out where these clips go in the harness?...
Where the existing ones are now (or were, if they're broken). Originals were included with the harness and wrapped with the wire bundle.
Old May 2, 2016 | 02:30 PM
steffan's Avatar
steffan
yes of course but, mine only has one
Old May 2, 2016 | 03:30 PM
Easy Mike's Avatar
Easy Mike
There will be corresponding holes in the headlight header bar at the push pin locations. Off the top of my head, I believe my 68 has three.
To harness clips
