Shifter Reverse Interlock
Old Apr 11, 2016 | 12:23 PM
guatemalanvette's Avatar
guatemalanvette
8th Gear
Default Shifter Reverse Interlock
I want to ask all of you for some advice in regard to a shifter reverse interlock that's situated on the shifter mechanism for my '69. I was about to order it from Willcoxcovette.com and there are two kinds of it. One is a 5/64 Inch (Part No. 42390) and the other is a 7/64 Inch (Part No. 42391). I am not sure if I should buy both of them and go from there or do I need only one of them?
https://willcoxcorvette.com/corvette...-64-inch-64-81
Here's link so you can see what piece I am talking about. Any of you have had experience with this?
Old Apr 11, 2016 | 01:00 PM
Alan 71's Avatar
Alan 71
Hi Mario,
I believe the interlock also acts as a shim… thus the 2 thicknesses.
I'd suggest you order one of each since you don't know at this moment what the shifter rebuild will require.
I'd think the thicker interlock helps reduce the 'sloppiness' a somewhat worn shifter sometimes has.
Regards,
Alan
Old Apr 11, 2016 | 02:19 PM
guatemalanvette
8th Gear
Originally Posted by Alan 71
Hi Mario,
Regards,
Alan
Thank you Alan for your advice, I really appreciate it. You are right, I should just get the two of them and go from there.
Regards,
Guatemalanvette
To Shifter Reverse Interlock
