1970 smog need help
https://www.corvetteforum.com/forums...needed-of.html
The fact that the 1970 didn't have any A.I.R. equipment and STILL had the higher compression makes it to my mind a really nice sb engine to live with.
Certainly a 1970 LT-! causes more excitement, but the 350 h.p. engine is quite special too!
Regards,
Alan
The Air Injection Reactor (A.I.R) system was used exclusively in 1968 and 1969 on Corvettes.
In 1970 the Controlled Combustion System (C.C.S) came into use. The C.C.S system used leaner carb setting and revised timing to reduce emission in place of the A.I.R.
The A.I.R system was the least performance robbing of the two, so it was used on all special high performance engines (LT1 and LS7 if it had made it into production). The lesser engines used the C.C.S system. The 1970 350/350 used the C.C.S.
All 1970 Corvettes also had a Transmission Controlled Spark (T.C.S) system that limited in what gears the vacuum advance would work.
John
A simple way to test if it is functioning correctly, get engine up to operating temperature;
Clutch in - put shifter in 1st or 2nd gear, idle should be in the 750/800 rpm range.
With clutch still in - move shifter to 3rd or 4th gear, rpm should increase an additional 300/400rpm above previous idle.
My questions, are what is gained or lost by removing the items? What else should I look for that was part of the system?
FWIW: I've owned the car for about 6 years and the only real modification I've found to date is someone installed headers and a CD player somewhere along the way. Other than that it appears the car was well cared for and no bubba fixes that I've run across. The engine was rebuilt about 8 years ago, before I bought the car. I'm just trying to learn everything about the car that I can.
With the TCS solenoid removed, I'm guessing you have vacuum going to your distributor all of the time. The car actually runs better that way, it likes vacuum at idle. GM installed the TCS system to block vacuum (reduce timing at idle) which increases combustion temperature to help with emissions output. Higher temps equal less emissions.
Temp sensor removed? Was it just replaced with a plug or was the head replaced with a unit without a temp sensor hole?
The TCS relay should be mounted to the firewall just to the right (drivers side) of the wiper motor. It has three single wire plugs going to it.
The transmission switch is located on the drivers side of the transmission, just below where the forward shift linkage attaches, it has a single wire plug going to it.
