Alternator amperage
Old Apr 23, 2016 | 09:47 AM
antoniov1's Avatar
antoniov1
Default Alternator amperage
I got a 82' and need to know if I got a 70 amp alternator
or non 70 amp how do I tell?
Old Apr 23, 2016 | 06:41 PM
carriljc's Avatar
carriljc
Default take a look at this thread:
it has images and whatnot for 82 alternators:
see post #9 for image of where amps are etched/stamped into case:
https://www.corvetteforum.com/forums...my-1982-a.html
Old Apr 23, 2016 | 06:43 PM
vbgod1's Avatar
vbgod1
I can't tell from the picture, but almost all GM's I have ever seen have had it stamped on the case somewhere. Your pic makes me think it has been painted, so it may be under that.
Old Apr 24, 2016 | 03:14 AM
LT1M21Vette's Avatar
LT1M21Vette
Don't know, but your wiring screams "zero amp soon"...
Old Apr 25, 2016 | 08:28 PM
antoniov1's Avatar
antoniov1
What's wrong with the wiring? I found the numbers on the front of the alternator I couldn't see it cause it was a little dusty
Old Apr 25, 2016 | 11:56 PM
sullyman56's Avatar
sullyman56
Old Apr 26, 2016 | 03:49 AM
David Sadakane's Avatar
David Sadakane
4th Gear
I may be young (21) and inexperienced (this is my first post on a car forum ever) but I have an '82 that I've been working on with my uncles and can tell you that the above is spot on.
That said, I read that 70A was stock when I had to get mine replaced and that if its the original part you should be fine. Those numbers should be right under the tensioner bolt on the belt side but can't tell from that picture. You're looking for something like a "70A" stamped on it
Old Apr 26, 2016 | 07:05 AM
gungatim's Avatar
gungatim
wiring looks like crap, broken insulation, missing plugs, crimp connectors, etc.
your alternator is a 10si, they came in 37,42,55,61, and 63 amp versions. if you had AC, and was a 70 amp stock, it would have been a 12si alternator. what you have is not original, and old (notice the smaller rear bearing), and since it's been painted and rebuilt, the wiring hacked, it's anybody's guess what is actually inside that case. the case may not even be a GM case as over the years they have been cloned in rebuild houses...
To Alternator amperage
