82 Power window harness routing?
Old Apr 25, 2016 | 03:24 AM
alconk's Avatar
alconk
Default 82 Power window harness routing?
Does the power window harness go through the first vertical window track in the door or below, behind or?? AIM does not show in detail. And what I mean by through is if you remove the track there is a bracket that allows it to attach to the door at the bottom and would act as a tiny tunnel as you will for the harness to go through if that the way it's suppose to be routed.
