Belt slipping
Old May 1, 2016 | 11:47 PM
74redstingray's Avatar
74redstingray
Default Belt slipping
Ok, so I've been chasing this ghost for over a year. Several gray hairs later and countless shots of whiskey, no resolution! 74 corvette 454 4-speed with power steering and factory A/C. Motor was rebuilt about a year or so ago, decided to powder coat all of the pulleys except for the PS pulley. I've been chasing a squealing belt issue and cant resolve the problem. I've installed new belts, powder coated pulleys, sanded powder coating off, installed new fan clutch, alt pulley, re-powder coated pulleys, I'm at a loss. A GM mechanic recommended I install the original Idler pulley GM # AQ 3952332, said it would resolve the issue, funny thing is, it wasn't on the car a few years ago and I didn't have this problem. I need help before I become an alcoholic!!!
Old May 2, 2016 | 12:02 AM
L Holmes's Avatar
L Holmes
Can you narrow it down to which pulley is squealing? A/C, Steering, alt? I had this issue once and what I did was spray a bit of water on one pulley at a time. If it still squealed I moved on to the next pulley until I got the squealing to stop or reduce greatly for a minute until the water was gone. In my case it was the alternator pulley. I then removed the alt. pulley and use a very coarse emory cloth to rough up the belt surface of the pulley so that the belt had a more aggressive surface to grab. It worked for me.
This is all assuming you dont have an alignment issue or bad bearings in a water pump, alt., a/c compressor.
Old May 2, 2016 | 12:03 AM
71 Green 454's Avatar
71 Green 454
What size belt are you using for the crank to water pump pulley?
Old May 2, 2016 | 12:12 AM
74redstingray
I decided to remove each of the three belts one-by-one to see if I could narrow down which one is slipping. After removing the A/C and the Alt belts, the last belt left on the car was the power steering belt, its squeals like a stuck pig! I noticed the PS pump looked a little off line so I shimmed it with two washers, seemed to line the pump up better. Changed the water pump just for giggles, waste of money.
Old May 2, 2016 | 12:31 AM
74redstingray
The A/C belt is a 15490, the P/S pump is a Gates 9440, and the Alt is a Goodyear 17325. The problem is, the depth of the pulleys seem different therefore a thicker belt will ride differently coming from, say, the water pump pulley to the power steering pump pulley.
Old May 2, 2016 | 09:10 AM
7T1vette's Avatar
7T1vette
There are differently designed belts, too. They have differently angled sides. If the belt design doesn't match the pulley design....SCREECH!!!
Recheck the belt and P/S pulley to make certain they match properly. Then, use a piece of 150 grit sandpaper to scuff the sides of the P/S belt. With all that screeching, the belt is likely glazed and will easily slip.
Old May 2, 2016 | 09:55 AM
71 Green 454
OK, but what about the 4th belt.....crank to water pump that uses the idler pulley? I wouldn't trust my P/S belt to drive the W/P, Alternator, and Compressor.
Old May 2, 2016 | 11:37 AM
74redstingray
That was something I've considered, I have a NOS idler pulley but had never decided to use it. The motor has been modified, could that, plus the absence of the idler cause the belt to fail under load?
Old May 2, 2016 | 11:42 AM
74redstingray
The PS belt sits just above the rim on the PS pulley, but seats below the water pump and crank pulleys, in guessing the grooves are different?
Old May 2, 2016 | 12:03 PM
71 Green 454
Probably, could you post a picture of your belt configurations?
Old May 2, 2016 | 12:12 PM
74redstingray
Absolutely, STBY....
Old May 2, 2016 | 12:30 PM
71 Green 454
Paging forum member LS4 PILOT......he changes his '74 454 belts every 5 years.
Look at the LS5 belt configuration in the diagram. It also shows the idler pulley pressing against the crank to water pump belt.
To Belt slipping
