Direct Lift Question
Says "DRIVE THRU" width is 80 1/2" I assume on ramps. There are gusset plates that limit the drive on width.
Inside to Inside of columns is 94" so anything narrower than that would drive under I guess. There are base plates on the columns but I did not bolt it to the floor. I would recommend NOT driving on the base plates for fear of pulling the columns in with load on them.
BTW...I have one that model and LOVE it. Very well built for the money.
The only restriction in the PPS model is weight and length. It will not lift a full size dually truck. Nor would I try to lift a 1 ton truck....other than that I think your good.
What is your daily driver? I could measure my lift if you need a certain measurement.
Can go on the ramps as well.
An Avalon should be no problem.
You should also look at the liftsuperstore lifts as well for comparison, if you haven't already.
hzz
I believe the liftsuperstore lifts are located in Oakville which isn't far but also noticed they're a bit more expensive. Which model directly compares to the PPS8 so I can compare more on an equal basis?
hzz
I think the Quatro-Stacker DX 8,000 is the comparable model.
I have a direct lift pro park 8 plus and a restomod stacker XL 9000lb from the lift superstore.
For storing cars, they are both about equal.
For working on cars, the restomod is much better. The distance between the ramps is larger, giving you more access underneath.
Also, the restomod I bought is a 220V, the direct lift is 110V. If I remember, there was no extra charge for 220V form liftsuperstore, but there was from direct lift.
The difference is in lifting speed...the restomod lift raises up much faster than the direct lift. Doesn't seem like a big deal, until you're working on a car and have to raise and lower a few times. The direct lift seems to take forever once you have the restomod.
Hope this helps
