Changed Dustributor, Now Radio Static
Old May 13, 2016 | 05:21 PM
nivensid's Avatar
nivensid
Default Changed Dustributor, Now Radio Static
Good Friday evening all, I have a 78 vette with basically stock engine and 350 turbo auto. I changed out the tired factory HEI distributor today with another one. New CFR 65K HEI Distributor.
The swap took just a few minutes and the car runs great. Now the radio picks up ignition noise. I can hear every cylinder fire through my speakers, leave the ignition on and cut off the motor and all is good.
I changed nothing but pull and replace the distributors.
Sure would like to listen to the radio again, any suggestions?
Old May 13, 2016 | 05:50 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
do you have one of these...pic compliments of Willcox
http://repairs.willcoxcorvette.com/w...stallation.pdf
Old May 13, 2016 | 08:41 PM
nivensid's Avatar
nivensid
I will check tomorrow for the tach filter. What has me confused is before the distributer change I did not have this problem. The radio sounded as it should so something had to change?
Old May 13, 2016 | 11:54 PM
7T1vette's Avatar
7T1vette
Tach filter has nothing to do with radio noise. It prevents voltage spikes from being read on the tach as additional RPM.
For limiting ignition noise, the plug wires should be resisance wire type; there should be some metal (or mylar) shrouding around the distributor area and that shrouding must be electrically grounded. On earlier C3's (points type), the ignition coil had a filter capacitor attached with it. Not sure what 78's had in that regard.
Old May 14, 2016 | 06:13 AM
nivensid's Avatar
nivensid
Thanks 7T1vette, Guess I have some investigating to do, all I did was pull the old distributor and drop in a new one. Never had a problem with the tach either way. The radio worked with no issues before the change so the plug wires I would assume are the resistance type. The only difference I can think of is the new distributor has a 65K coil. I am shooting in the dark here but I will change the coil with the one from old distributor to see if it makes any difference.
Old May 14, 2016 | 06:14 AM
mikem350's Avatar
mikem350
Check grounds for the antenna coax, radio antenna and wires.
Before you swap the coil, make sure the screws for the new coil are tight. Look at the rotor button and other parts too.
Old May 14, 2016 | 06:41 AM
nivensid's Avatar
nivensid
Will do thanks for the help.
Old May 14, 2016 | 07:08 AM
briankeery's Avatar
briankeery
Have a look on your new coil where the grounding strap makes contact. If it's painted, you need to scrape that coating off so you get a good ground connection.
Old May 14, 2016 | 04:09 PM
7T1vette's Avatar
7T1vette
That may be where your problem is located.
Also, the grounding path for the distributor is actually from the dist. body, to the dist. clamp, through the hold-down bolt and then into the engine block. If all that stuff is painted up, you won't get a decent ground to the distributor and ignition system. It may run OK, but that might cause the noise in the electrical circuit.
Another thought: Where is the radio power wire routed? For least noise, you want it to go directly to the battery (through a fuse, of course) or as close to the battery as possible. There is no better 'noise' filter than a big battery.
Old May 14, 2016 | 05:13 PM
mikem350's Avatar
mikem350
The battery acts a filter for lower frequencies, like alternator whine. The ignition popping is RF energy spikes.
All good advice above.
Old May 14, 2016 | 05:47 PM
nivensid's Avatar
nivensid
I put the old cap and coil on new distributor and the radio is back to normal. Thanks everyone for the help.
To Changed Dustributor, Now Radio Static
