Help Gas leaking
Old May 31, 2016 | 08:13 PM
Mbuschsr's Avatar
Mbuschsr
Originally Posted by Alan 71
Hi Mb,
A change in idle speed often does indicate a vacuum leak.
Is the rest of the EEC system in place and the hoses/lines run?
I'd think the idle should be re-set with everything in place that you're going to use after checking for vacuum leaks.
Regards,
Alan
That was going to be a question for another day. It that everything to the ecc is hooked up except the short hose that goes to the metal line in front of the carb is hooked to the metal line but the metal line goes around the carb then towards the rear and ends. It is not hooked to anything.
Thanks for sharing your knowledge.
